How many miles since g/box was refurbed?. Cus with the td6 it's a case of when not if..
mine was refurbished at 75,000 . I also had sticking calipers on the rear and transfailsafe approx every 2,500 miles, limp mode also this always happened when pulling away or uphill.
Not long had mine done as the transfailsafe started to appear at speeds between 40 to 60 mph. But curiously it didn't go into limp mode.
eventually the fuel consumption went down and the g/box was slipping badly.
the lads at neil smiths in cannock couldn't replicate what I said had happened, but I gave them full instructions to do a full strip and rebuild.
On stripping the box it was found that the box was in desperate need of a rebuild.
these are my findings only, but if you have a good read about td6 gm g/box you will find mostly the same as they are not very strong.
Oh and my g/box had done just over 60,000 since last refurb.
hope yours is ok but please be aware of the gm box.
greg.
