Home > Maintenance & Mods (L322) > starting problem sometimes |
cowman Member Since: 24 Jul 2013 Location: United Kingdom Posts: 186 |
i have had a starting problem ,sometimes it takes a few turns to start and other times it fires straight up .fault codes 1260 and 09f6.i have changed the pump on the side of the tank and put a new filter on ,it doesnt do it all the time ,has anybody had this problem ,thanks. |
13th Oct 2015 12:25pm |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
I had this on my TD6 and was two failing injectors |
13th Oct 2015 2:31pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Does your Glow Plug light come on? and do you wait for it to go out before starting? It can make a difference to how quickly it all fires in to life
13th Oct 2015 2:46pm |
yes the glow plug light does come on ,i do wait for it to go off ,i have done a bleed off check on the injectors and they seem to be fine,it does it when cold or hot |
13th Oct 2015 4:27pm |
Possible air leak in the fuel pipes, intermittent glow plug timer? Tricky one that, it's sooooo annoying when it only does it some of the time Might pay you to get it to a diesel specialist (Bosch Agent), they should be able to throw some light on it, otherwise you could be changing parts till the cows come home and still not sort it Yesterday I couldn't spell Engineer... Today I are one!
13th Oct 2015 5:20pm |
OOOOOO what about the immobiliser in the key? maybe the ECU is having a hard time seeing it, hopefully someone can shed some light on it. I don't know if it knocks out the whole starter system or just the fuel, which would allow it to turn over but not start. I'm sure that I read about the transducer pick up playing up on here, but don't ask me where Yesterday I couldn't spell Engineer... Today I are one!
13th Oct 2015 5:25pm |
found the problem the fuel pump relay in the boot, is this just a normal 40 amp relay ,can i get one from a motor factors or does it have to be main dealer part only,also found i have 3 glow plugs out so doing that this week ,it doesnt have trouble starting on 3,thanks for all the help and advice. |
24th Oct 2015 10:24am |
i have opened mine and you are right the contacts are burnt,you dont have the part no do you,thanks. |
24th Oct 2015 10:57am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3973 |
No I don't have a part number for the relay unfortunately, I seemed to remember I just asked Dan for a fuel pump relay.
24th Oct 2015 12:09pm |
FYI a lot of those relays in the boot fusebox are just standard type relays, I know that the EAS is a 70 amp one. Have a look at the numbers on the terminals and check them on google, there is a very good chance that it's a std relay and you can save a few quid, by not having a landrover sticker on it Yesterday I couldn't spell Engineer... Today I are one!
24th Oct 2015 9:44pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Idea for company --- making Land Rover stickers !! 2015 4.4 AB
24th Oct 2015 9:51pm |
^^ Yesterday I couldn't spell Engineer... Today I are one!
24th Oct 2015 10:52pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7796 |
Perhaps a daft question -how do you diagnose that ? Turn the ignition on and listen for the pump, or will it run but not ideal power as relay is dodgy, or do you have to get the old voltmeter out ? 2011 Range Rover Vogue SE 4.4 TDV8
25th Oct 2015 6:37am |
you can test the pump with a piece of wire with a male connector on it take the relay out and put the spade connector in the top terminal then touch it on the live red wire you can hear the pump if it is ok ,or swap relay with the next one to it to test. |
25th Oct 2015 9:20am |
