Home > Wheels & Tyres > Sudden loss of pressure in rear offside tyre, but then ... |
You need to have a 4 wheel alignment done, would be worth checking the rear joints to make sure they are all ok before having it done |
29th Sep 2015 10:10pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
It sounds like your rear bushes are shot, or, the suspension is damaged (unlikely, but a consideration), either way there is something not right at all and I would get it checked asap
29th Sep 2015 10:18pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Very much seems like its had a bump to me too! If it was 10yrs older i would suggest the bushes were cup put but at 3 yrs old! Get the alignment checked first sir
29th Sep 2015 10:29pm |
JJ Member Since: 06 Feb 2015 Location: Aberdeen Posts: 6 |
Thanks guys. Car looks to be in good shape underneath so I think a dunt is unlikely albeit I'm now a bit concerned.
30th Sep 2015 4:40am |
mike whiskey Member Since: 11 May 2015 Location: Huntingdon Posts: 114 |
A lucky escape, and yes disappointing that the tyres should be so worn and worn unevenly, but seriously do people not at least look at their tyres once in a while?
30th Sep 2015 6:47am |
Sounds like alignment / geometry. My Bro had the same on a brand new X5, it was a long way out even though the car was brand new. BMW sorted it and replaced all 4 tyres for free at 4600 miles as it had all but eaten the things.
30th Sep 2015 6:55am |
That sounds like someone had the manual upside down when it came to suspension setup time, I would say that you've a strong case for new tyres x4 on the stealer, as it's not normal ware and tare. It's a mechanical fault, or should I say it's the fault of the mechanic, sorry I mean spotty technician (mechanic's are older and wiser), who has played with the settings and got it all Pete Tong. Either way you could argue that the car was not set up properly, and therefore not fit for purpose and under the sale of goods act I want your shirt
30th Sep 2015 8:26am |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
They're roughly set up when they leave the factory. But the original selling dealer is supposed to have a 4 wheel alignment done as part of the PDI (because the suspension settles during delivery). Like a lot of things on PDI's some dealers cut corners and don't bother doing the more time consuming bits of it. So then the car runs around with bad geometry for months even years until some one decides to have it checked and/or gets fed up of replacing tyres.
30th Sep 2015 11:05am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
---and whilst the car has been dragging itself along, with poor alignment, (each wheel has been trying to stretch the car wider...) -your mpg will have been worse, so when its time for a bit of free alignment, and tyres, i'd top it off, with a tank of fuel.....if you want to give some good praise and customer feedback...
30th Sep 2015 12:06pm |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 |
You're not running on 22's by any chance are you?
30th Sep 2015 9:31pm |
UPDATE. Need the car for work so got four GG's fitted yesterday and will get a third party to check alignment tomorrow then discuss with the dealer. The front tyres weren't too bad but the rears are both shot. I don't have time to mess around and wait on feedback from the dealer re them fitting new tyres but I still want to challenge the poor alignment. |
1st Oct 2015 5:32am |
You are entirely correct. I check the tyre pressures and levels fortnightly and am an engineer to trade so, yes, should know a lot better. Lesson learned re getting under the vehicle once in a while. Regarding the "timely warning" comment, one of the lads at work checked his truck yesterday as a result and found his were also wearing unevenly (VW Amarok). |
1st Oct 2015 5:35am |
Thanks mate. They're just the standard 20s. |
1st Oct 2015 5:37am |
UPDATE. Wheel alignment was badly out and symmetrically so. Time for conversations with the dealer. |
2nd Oct 2015 12:54pm |
