Home > Technical (L322) > Loosing coolant |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 |
Hi Danny,
28th Sep 2015 9:44pm |
DK Member Since: 28 Sep 2015 Location: South Shields Posts: 8 |
thanks Ray, i'm open to any and all suggestions and i'll check the evap when i get home, however i would have assumed if it was a leak from the hose it would have showed up on the pressure test... that said it's always worth a check as the garage may have missed something!!
28th Sep 2015 9:50pm |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
Wasn't there a thread somewhere about the wrong expansion cap used on some cars? |
28th Sep 2015 9:53pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
Has the radiator been renewed in the last couple of years, if not I would look there. Due to the high temp and pressure even the tiniest leak will not evidence itself as the coolant just evaporates leaving no trace. Possibly something horrible going on on the side you can't see! .
28th Sep 2015 11:21pm |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 |
If I remember the expansion tank and sensor checks to see if the right mix of coolant is in the engine and if not then will show the low coolant level.
28th Sep 2015 11:59pm |
thanks, guys
29th Sep 2015 12:42am |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
Your car is exactly the same as mine - I had a similar problem which was a combination of ....
29th Sep 2015 7:44am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1373 |
On my 2004 4.4 I had the radiator replaced as it was leaking at the bottom corner, I think when it was 5 or so years old. I was told this was a common problem.
29th Sep 2015 11:12am |
Stuart Member Since: 06 Feb 2011 Location: Cambridge Posts: 85 |
Hi Danny
29th Sep 2015 11:19am |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 |
Expansion bottle, inboard seam underside of it.
29th Sep 2015 11:56am |
Thanks again, this is my first thread and i'm blown away by how helpful you are all being.
29th Sep 2015 9:26pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
On the BMW engine, there is a plastic pipe adaptor on the back of the cylinder head that goes pop (mine had a fairly recent one when i bough the car), the rad on mine was leaking, with the fan then dispersing the mist and hiding the leak, the temperature sender on the water pump was also weeping. The coolant tanks burst (the BMW cars do this too) and the rad caps had a revised design with a lower pressure opening. and the water pumps have a habit of failing on them.
30th Sep 2015 12:01am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8186 |
What he said ^^^^
30th Sep 2015 9:31am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
as said above, ther are easy places to look and check for dampness etc. ie bottle and rad, however, there is another suspect area you can very easily rule out, with a couple of cotton buds, maybe stuck on a stick to check for dampness,
30th Sep 2015 10:37am |
