Home > Technical (L322) > Deplorable steps grinding
webber
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
Hi all
My passenger side deployable step is very noisy when it moves in or out, like a grinding noise. I cleaned up all the hinges and re-greased them but it made no difference.
Is it likely to be the motor itself making the noise? Looks like genuine motors are about £150. I'm just wondering if anyone has experience of fitting one, was it an easy job?
Looks like a few bolts holding it in, but I'm not sure how you get the motor spindle out of the bracket, presumably with a bit of force and pulling!!
Any advice appreciated, cheers Thumbs Up
Post #346961 10th Sep 2015 8:24am
sounds like a new motor is needed but our Craig will know.... ... - .- -.
Post #346962 10th Sep 2015 8:30am
Yes it needs a new motor i would suggest! or, if you don’t use the ns one or don’t have the time for a while simply unplug it? Whistle Laughing Rolling Eyes
PITA to change though sir Rolling Eyes Hence why it was NOT changed prior to your purchase! Rolling Eyes
Post #346976 10th Sep 2015 10:06am
johnboyairey
i'd say deplorable predictive text, on your DEPLOYABLE steps issue
Post #346985 10th Sep 2015 10:45am
webber
I'll probably just get the local specialist to change the motor then if it's a tricky job, to be fair I can live with it for now, it's just slightly annoying!
And yes I didn't notice the title!! Thanks to my iPhone predictive text for that one Laughing maybe a good description though!
Post #346990 10th Sep 2015 10:50am
SoggyBottoms
United Kingdom 2007 Range Rover Vogue Supercharged Zambezi Silver
mine started out like that and then began to remain out for a few seconds longer. then one day it caught me out by sticking out when I was going over a kerb just after start up. ripped the whole step off.
follow Craig's advice and unplug it so you don't have a £150 job turn into £2k
Post #347028 10th Sep 2015 1:11pm
webber
Thanks for the advice guys, I'll unplug it and book it in to be fixed Thumbs Up
Post #347069 10th Sep 2015 4:36pm
