![]() | Home > Maintenance & Mods (L322) > anyone fixed a failed brake light in 2010 tail light? |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
NEVER heard of one failing! |
lee37Vernon Member Since: 12 Oct 2014 Location: Aldershot Posts: 74 ![]() ![]() ![]() |
Yes. Plugs in both sides are the same so just swapped lights over. The n/s light works perfect when plugged in the o/s.
WOW... Ill have a look tomorrow morning as i think we may have one spare sir |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6746 ![]() ![]() ![]() |
I know you can't get into the connectors from the back, as I had to Dremel the front lens off of one I bought to find out that the indicator wasn't working due to the plug not being plugged in! The whole light assembly pulls out through the front.
That's what I figured Alanm_3, totally out of sight, I'm assuming I'm going to need to change the led itself which should be behind the diffuser.
This is what the inside looks like
Thanks, that's helpful!
Yes, that's correct. Got - 2017 SDV8 Autobiography in Loire Blue
Cheers.
I've now used a multi tool to remove the back of the light to reveal this....
Da daah....
Glad you got it sorted Lee. I think your right, cutting a hole on the back is definitely a neater option than cutting the lens off and trying to line it all up again |
Worked well. Sold the lights now too! No complaints from buyer
