Home > General > Broke The 20 mpg mark |
doclees Member Since: 24 Jun 2015 Location: PA Posts: 672 |
Enertia can be a friend or an enemy. Starting and hills just crush gas mileage. Starting from a stop going up hill the consumption gauge reads in the negative! |
25th Aug 2015 2:31pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
DannyH,
25th Aug 2015 8:18pm |
Yep. Im on the Eccomodders site. It is interesting stuff. Most do that stuff for the environment. I do it for the environment of my wallet. But no I am not going to change the looks of the body for such a small improvement that will happen. The biggest bit of info that site provides for our flying bricks is how to work the throttle to out advantage. My first flying brick was a 95 Jeep wrangler with the 4.0 and stick. Went from 16mpg highway to 24+. The magnaflow cat back made no perceivable change. The smaller lighter tires made no real change. The K&N air filter made no change. Removing the Kargo Cage did as with anything dealing with air resistance. 16 to 18 right away. Get into 5th as soon as possible. Engine brake down hill vs coasting. Draft the big trucks or another wrangler when possible. |
25th Aug 2015 8:25pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
You only have to look at what the car manufacturers are doing on their ultra low emissions cars.
25th Aug 2015 8:41pm |
When I bought the Beast about 6 weeks ago the consumption 1 and consumption 2 was reading 13.5. On my first trip home from the gas station (petrol) I reset consumption 1 and it read 14 when I arrived. Just last night I used the same station and it read 19.9 on the same trip home. Consumption 2 I haven't changed since my first fill up. It reads 17.4. I drive with a lite foot. Slow starts, accelerate down hill and coast up hill. That said the wife has it this week. |
25th Aug 2015 10:00pm |
DannyH Member Since: 30 Apr 2015 Location: Hull Posts: 221 |
unfortunately the v8 sounds so good when accelerating that it urges you to accelerate more often... goodbye dear petrol you treated my ears so well haha. Dan
26th Aug 2015 8:50am |
Oh you should have heard the beast with the old twin magnaflow pipes. They stayed with the PO because he wanted them for his other 2004. A lovely rumble without being too loud. It was like going from a stock Triumph Speedmaster to one with TORS. |
26th Aug 2015 12:32pm |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 |
Using Cruise control will normally increase fuel consumption. e.g. If you set it to 65mph when driving on a motorway, the car will often change down a gear or increase revs when you are driving up a gradient or have slowed down for traffic, as it is trying to get back up to 65 as quickly as possible. Switch off cruise control and modulate your throttle manually, allowing the car to slow slightly when you are ascending a gradient. This way is definitely more fuel efficient. No longer FF owner but still interested. Present car Jaguar XE ............................................ Previous car Td6 SE ................................ Previous LR- Disco 300TDi Auto |
29th Aug 2015 12:14pm |
kajagoogoo88 Member Since: 12 Feb 2015 Location: aylesbury Posts: 50 |
9mpg? Take the handbrake off....? Current:
31st Aug 2015 2:15pm |
lee37Vernon Member Since: 12 Oct 2014 Location: Aldershot Posts: 74 |
Did somebody say 9 MPG..
4th Sep 2015 10:06am |
OK officially broke the real 20 MPG mark with 21.7. So after adjusting for computer error I cleared the 20 MPG US. On my 2k mile trip to Florida it became clear that AC does lower gas mileage on this beast . That and cruise control would drop it about 2mpg. The flatter it got the better the mileage. Duh. I wasn't in the Florida panhandle for enough miles but I'm sure I could break 23mpg on the computer. |
10th Aug 2016 3:49pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
Gave up looking at consumption 30k ago mind you it is better than most of the cars I have owned so would guess at 14 |
13th Aug 2016 5:55am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1526 |
On a recent 1100km trip, I averaged 12.7 l/100km (22mpg Imperial/18.5mpg US). I should remove the roof rack. On my P38A, the roof rack increased consumption by about 10%, Ron B. VK2OTC
13th Aug 2016 8:32am |
nemmi69 Member Since: 16 Jun 2015 Location: Peterborough Posts: 101 |
Im might be able to get 20mpg if I put a block of wood under the throttle. What doesn't kill you is just bidding it's time. |
15th Aug 2016 7:58am |
