Home > Maintenance & Mods (L322) > anyone fixed a failed brake light in 2010 tail light?
lee37Vernon
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Hi all.
Had it pointed out to me that I had a brake light out, 2010 led tail lights on a 2003 with the one stop fix all box... Been working fine since I fitted them, I've plugged the left into the right side to prove its the light and not the box /wiring.
Any way, question being has anyone fixed one of these? I think I'm correct that the old taillight had led brake light anyway so considering chopping the two up. Not a lot to lose now I suppose anyway..
Or does anyone have a 2010 (grey) o/s led tail light for sale?
Post #341540 9th Aug 2015 8:37pm
NEVER heard of one failing! Shocked Shocked Shocked
Are you 100% sure its the light?
Post #341556 9th Aug 2015 9:34pm
lee37Vernon
Yes. Plugs in both sides are the same so just swapped lights over. The n/s light works perfect when plugged in the o/s.
However the o/s light (brake) doesn't work when plugged into either side.
Guess I'm the unlucky one, considering cutting a hole in the back to have a look, as I know the lenses won't come off on these later lights.
What a Censored nuisance Big Cry
Post #341558 9th Aug 2015 9:41pm
WOW... Ill have a look tomorrow morning as i think we may have one spare sir Thumbs Up
If you don’t hear back please send me a PM Thumbs Up
Post #341561 9th Aug 2015 9:45pm
I know you can't get into the connectors from the back, as I had to Dremel the front lens off of one I bought to find out that the indicator wasn't working due to the plug not being plugged in! The whole light assembly pulls out through the front.
In hindsight, using a biggish hole saw to get into the back might be the best option. That way you can put that cut out back in with some sealant. Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #341566 9th Aug 2015 9:52pm
lee37Vernon
That's what I figured Alanm_3, totally out of sight, I'm assuming I'm going to need to change the led itself which should be behind the diffuser.
Or maybe it's better off going on eBay and let it be someone else's problem..
Thanks Craig Thumbs Up
Post #341570 9th Aug 2015 9:59pm
This is what the inside looks like
[/img] Got - 2017 SDV8 Autobiography in Loire Blue
Post #341576 9th Aug 2015 10:20pm
lee37Vernon
Thanks, that's helpful!
What did you cut, along the seam for the clear lense?
Post #341627 10th Aug 2015 12:09pm
Yes, that's correct. Got - 2017 SDV8 Autobiography in Loire Blue
Post #341651 10th Aug 2015 1:51pm
lee37Vernon
Cheers.
Just ordered two new ones as got a good deal, will be pulling old one apart then..
Post #341879 11th Aug 2015 6:01pm
lee37Vernon
I've now used a multi tool to remove the back of the light to reveal this....
Hopefully it'll come out and I can get the led panel working. 2003 4.4 Adriatic Blue FF
Post #344620 26th Aug 2015 9:22pm
lee37Vernon
Post #344622 26th Aug 2015 9:22pm
lee37Vernon
Da daah....
Spoke to someone who was going to look at the PCB for me when I found another light local to me with a broken lense.
Made one good one from the two, polyurethane sealed the back section back on and its perfect! Well happy, shame I've already bought two new ones but hey ho.
I'll be posting these in the for sale section soon if anyones interested.
Thanks for the inside pictures Alan, really helped and I think removing the back is a much much better way than removing the lense and trying to neatly replace it.
Post #346026 4th Sep 2015 9:28am
Glad you got it sorted Lee. I think your right, cutting a hole on the back is definitely a neater option than cutting the lens off and trying to line it all up again Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #350311 2nd Oct 2015 11:20am
lee37Vernon
Worked well. Sold the lights now too! No complaints from buyer
Seems to be a few broken lensed one around to rob for the innards 2003 4.4 Adriatic Blue FF
Post #350388 2nd Oct 2015 9:41pm
