Home > Technical (L322) > neg nut of shocky tower
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
Whilst undoing all the nuts so I can get battery out to give it a proper charge.
I've lost the neg nut (the one on the shocky tower) somewhere in the engine bay. Rolling Eyes
As yet I haven't found it.
Is it essential to have that nut on or not.
Thanks
Post #341222 8th Aug 2015 3:00am
I have no idea what a 'shocks tower' is Confused
Do you have a photo ?
Post #341233 8th Aug 2015 8:34am
If LR deemed a nut necessary it should still be there. Thumbs Up Wink
You don't need to remove the battery to charge it, it quite happily charges on the car without any problems.
"Shocky " shock absorber?
Post #341236 8th Aug 2015 8:46am
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
If you can't find it then just replace with an equivalent standard nut. You need a nut on there because from memory it secures the suspension leg (it might be an extra point though), you don't necessarily need a neg post terminal which is just there to aid jump starting.
Post #341239 8th Aug 2015 8:57am
Sounded like a new Harry Potter book when I first read it Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #341240 8th Aug 2015 9:04am
Weejock
Looking at a photo it's an extra point purely for the negative which is not structural, you don't necessarily need it as it's only there for jump starting. Whack a couple of ordinary nuts on there.
I suggest you try and find the original nut though, not because you need it but because you don't know where it's sitting right now, it could cause a potential problem later on (wear through another component).
Post #341242 8th Aug 2015 9:12am
littlecub
Thanks weejock.
Post #341244 8th Aug 2015 9:14am
Zirconblue
if it comes to it i doubt the original nut will cost a lot to buy from a dealer.
Post #341248 8th Aug 2015 9:32am
Laughing Laughing you obviously don't know Land Rover Australia then . 2008 MY Supercharged
Post #341251 8th Aug 2015 9:37am
Zirconblue
I know Land-Rover UK, while they do rip you off on most things, small fixings like nuts bolts and clips aren't normally very expensive.
I mean ok, you might pay £1 for a plastic trim clip that probably cost pennies to make, but still it's only £1.
I'd still ask them. I mean you don't want to waste an hour trying to find something that fits when it would have only cost £5 or something for the proper part.
Post #341253 8th Aug 2015 9:43am
