![]() | Home > Technical (L322) > neg nut of shocky tower |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7975 ![]() ![]() ![]() |
I have no idea what a 'shocks tower' is |
If LR deemed a nut necessary it should still be there. |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
If you can't find it then just replace with an equivalent standard nut. You need a nut on there because from memory it secures the suspension leg (it might be an extra point though), you don't necessarily need a neg post terminal which is just there to aid jump starting. |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6746 ![]() ![]() ![]() |
Sounded like a new Harry Potter book when I first read it |
Looking at a photo it's an extra point purely for the negative which is not structural, you don't necessarily need it as it's only there for jump starting. Whack a couple of ordinary nuts on there.
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 325 ![]() ![]() ![]() |
Thanks weejock. |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
if it comes to it i doubt the original nut will cost a lot to buy from a dealer. |
I know Land-Rover UK, while they do rip you off on most things, small fixings like nuts bolts and clips aren't normally very expensive.
