Home > Technical (L322) > Trailer light
Stryke
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Trailer light
Hi guys,
Having a slight issue.
The green trailer light on the dash seems to light up when I am on the move (I have no trailer attached) and when turning off the ignition I get "check trailer light" on the display.
Any advice?
Thanks.
Post #339748 29th Jul 2015 5:27pm
Do you have a towbar attached?
If so is it a genuine wiring set or an aftermarket one. Chances are there is some corrosion in the back of the sockets. Causing a small short or ground problem, worth taking them off and checking Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #339749 29th Jul 2015 5:32pm
Stryke
Hi there,
Yes I have the towbar feature (genuine Land Rover).
Thanks for the suggestion, will give it a go tomorrow.
Post #339750 29th Jul 2015 5:34pm
