Home > Technical (L322) > Random suspension lowering when parked/locking doors.
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
I've noticed sometimes after driving and parking that my Range will drop the suspension like an inch or so in the front after locking the doors. Sometimes this happens....other times is just stays put. Why is this? What makes the suspension want to raise (while driving) and then lower when parked sometimes and other times not? 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #339552 28th Jul 2015 2:24pm
When you are driving it is difficult for the FF to decide what is or isn't standard height, bends, pot holes, camber etc means that the system has to "guess" where it should be, when you stop and switch off it resets and goes to normal height (unless you pressed access) it will only do this with the doors shut so you see it do it after you get out...
Quite normal... Pete
Post #339558 28th Jul 2015 2:38pm
horse86
Ah ok...makes sense I guess. Was odd since my commute is mostly the same everyday and sometime it does it and others not. Just a quirky thing with the suspension....but man do I love the air ride comfort...so I'll put up with the quirkyness Smile 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #339566 28th Jul 2015 3:29pm
iKushtyy
England 2007 Range Rover Vogue TDV8 Stornoway Grey
Self-levelling suspension.. Levels itself when car is at rest..
Post #339650 28th Jul 2015 11:08pm
Fish
United Kingdom 2007 Range Rover Vogue TDV8 Rimini Red
I've noticed mine do it occasionally when sat at traffic lights. First couple of times I wasn't sure it actually happened Confused then I panicked a little thinking something was wrong Big Cry then I realised what it was doing Thumbs Up
Post #339659 29th Jul 2015 4:42am
Zirconblue
Presumably the level sensors have small steps in them. If you're on the cusp of one of the steps the suspension might move from one step to the other as occupants move about in the vehicle.
Post #339684 29th Jul 2015 9:23am
Hall effect sensor, totally linear, but the system has a + or - 9mm tolerance in standard mode...
That's why it's important when playing with an IID tool or similar to NOT put the car into tight tolerance mode... be up and down like a yo-yo.... Rolling Eyes
Thumbs Up Pete
Post #339724 29th Jul 2015 12:57pm
