Home > Technical (L322) > Washer Fluid tank tube path
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
OK here is another odd one. Just filled washer fluid a couple of days ago. Hadn't used it. Warning washer fluid low. Looking for leaks I see at least 2 hoses are disconnected. The pump for the rear window had no hose on it but one flopping near it. Seems to go towards the fender well. The pump for the windshield has a hose that comes up about a foot and has no connection. It is held on to the breather hose. As best as I can see the pump for the Headlamps has a hose attached and it looks like it comes forward under the headlamp.
Anybody have a clue what goes where? I'm assuming the long one near the rear pump should attach to that pump. Can't tell where the tube from the windshield pump goes to next. Thanks.
Post #336579 9th Jul 2015 1:32am
Any use?
Post #336600 9th Jul 2015 8:57am
doclees
Thanks for the effort but no. I have RAVE too and the link for the parts listing but nothing shows the path the tubes go. Perhaps in the daylight it will be easier. No I stand corrected. Seeing the path around the tank may help. Gives me an idea about where to look.
Post #336636 9th Jul 2015 1:00pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Look at the RAVE pic above, not the actual parts pics but the ghost of the RR front end. The rough path of the pipes are shown as black lines and looks about right from memory.
You need to take the arch/fender liner out for the pipe going to the windscreen. Windscreen washer line then comes up in the battery compartment somewhere to the nearest wiper where it will split and go to the other wiper. Headlight pipe goes straight to the nearest headlight, splits and then links across from there inside the bumper (runs long the top of the bumper bar).
Rear washer runs I think with the headlight washer line, then inside the cabin at the bulkhead and over the headlining to the rear.
Post #336680 9th Jul 2015 7:00pm
doclees
Thanks Weejock at first I thought the problem was just tubes that were off. I'm going to need to check the tank. Is it necessary to remove the tire as stated in the RAVE or can you work around it?
Post #336715 9th Jul 2015 10:06pm
Weejock
If you put the suspension in off road mode and turn the wheel you can undo and pull out the end of the liner to get to the washer tank, it's obviously easier with the wheel off but doable with it in place.
Post #336719 9th Jul 2015 10:23pm
doclees
That worked OK. I didnt need to remove the tank but could have. Had to clean the pump motor seals because of a previous oil leak and set them in fully. Also spliced the fluid lines, repaired a hole in one and corrected the path. I don't think it is necessary to remove any of the screws beyond the center of the wheel back. FWIW those "plastic nuts" have a metal sleeve that rusts around a thin shaft and they snap off with about 8 ft pounds of torque. I'll drill them out another day.
Post #336952 12th Jul 2015 12:21am
