Home > Maintenance & Mods (L322) > Silicon hoses for 3.6tdv8 vogue
Page 1 of 6 123456>
Blade74
Australia
ive been searching for a silicon air hose kit for a 2010 vogue TDV8.
Managed to find some for a RR sport.
Can anyone shed some light on where to buy them for a vogue.
Is it worth replacing them all or just the upper hoses?
Cheers
Post #334627 26th Jun 2015 9:42pm
rangie47
I looked into this too ,as I fitted them on my old td5 ,but my indy stated there no use on a tdv8 as they will keep popping off so stay with genuine 2007 tdv8 se ,stornaway grey
Post #334659 27th Jun 2015 10:03am
Blade74
Australia
That seems strange that the silicon ones keep popping off.
They can handle 21 psi boost in a td5. Surely they can handle the pressure of the tdv8???
It just seems silly that the original hoses split every few years and need replacing.
Not something you want to happen in a more remote area.
Post #334677 27th Jun 2015 12:08pm
Mikey
http://www.lhss.co.uk/land-rover-hoses/turbo-hoses/
Scroll to the bottom Thumbs Up
Silicone hoses will not keep popping off, and are a fit and forget upgrade.
My Disco 3 is running 23psi, and has been for the last 40k miles. Never had an issue Thumbs Up
Post #334679 27th Jun 2015 12:27pm
Blade74
Australia
Thanks Mikey. Thumbs Up
Post #334681 27th Jun 2015 12:45pm
ebajema
The CAC (Charge Air Cooler) turbo hoses are rated for 6 bar workin pressure Smile
I had to look at the OAT resistant ones, I already saw porridge being pumped through Smile Smile Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #334682 27th Jun 2015 12:47pm
rangie47
I totally agree about been a upgrade ,
as stated I fitted them to my td5 with no problems what so ever ,im just quoting what my indy stated
ps how much are the kits from lhss as it don't say on their site 2007 tdv8 se ,stornaway grey
Post #334737 27th Jun 2015 5:37pm
Blade74
Australia
This was the response I got from them.
Note the pricing doesn't include VAT as I'm in Sydney Australia.
"Thank you for the enquiry. Please see attached Land Rover silicone hose brochure for reference.
The cost of kit is £56.00 each.
Hose clamps @ £1.90 each. These are all stainless steel with inner sleeve. Very high spec.."
The Kit is known as a TDV8-V kit and has 6 silicon hoses.
I've ordered the kit and will probably get it in the next week.
Post #336086 6th Jul 2015 9:53am
ebajema
Thumbs Up Thumbs Up Thumbs Up MY 2010 5.0 SC Galway green and sand interior!!
Post #336111 6th Jul 2015 11:49am
Mikey
£56 + VAT is very cheap. Let us know how you get on with them Thumbs Up
Post #336115 6th Jul 2015 12:40pm
sasdiscos
United Kingdom 2010 Range Rover Vogue SE TDV8 Zambezi Silver
Very cheap indeed, i would also be interested in feedback of quality.
Steve You remind me of a young me, not much younger mind, perhaps even a little older!
Post #336140 6th Jul 2015 5:23pm
Blade74
Australia
It does seem very good for 6 hoses. Although 4 are very short.
I'm hoping they're good quality and will know once I put them on.
My car which I only bought a week ago has a whistling noise at a certain throttle position and is using more fuel than I thought it would or what I've read it should from other people with the TDV8 3.6.
I've inspected the two main hoses and couldn't see any leaks or splits.
If it doesn't fix it I'm not sure what could be causing the faint whistle? Maybe one of the turbo blow off actuators could be stuck open?
Post #336182 6th Jul 2015 9:33pm
The faint whistle is fairly normal seem to recall my 3.6 did it too at certain boost levels, mostly when cold. There is nothing that can't be fixed with a hammer😜😜
Post #336188 6th Jul 2015 9:52pm
Blade74
Australia
Mines seems to do it whether its cold or warm.
I have only driven the car for one full tank but have averaged 20 MPG or 14.0 L per 100.
The car did a mixed amount of city/motorway driving and i wasnt heavy on the throttle.
I'm guessing it should have been around 10 or 11 l per 100.
Post #336205 6th Jul 2015 11:08pm
rar110
Good work mate, I look forward to hearing your report on them. ______________________________
Post #336278 7th Jul 2015 11:43am
Page 1 of 6 123456>
