Home > Technical (L322) > AC clutch not engaging
Glynn
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
My AC clutch apparently isn't engaging, last week it had a new condenser fitted and a re gas and all worked well until sunday when no cold air coming out.
Had it to the garage where they fitted the condenser and, it's full of gas but is showing two faults
air quality sensor and line fault ( clutch I assume )
All fuses are OK.
Any ideas ?.
The guy said that a connector near the compressor is " bright orange" like its been too hot ??.
Post #335303 30th Jun 2015 4:44pm
i'd re-check the connections to make sure they are plugged in properly.. ... - .- -.
Post #335305 30th Jun 2015 4:46pm
Glynn
Which connections Stan ?.
I haven't actually seen it yet.
Post #335306 30th Jun 2015 5:10pm
this one.. ... - .- -.
Post #335320 30th Jun 2015 6:23pm
Glynn
Thanks Stan, I will check this when I get a minute.
I was thinking could it be a compressor relay ?, if so where would it be located.
Post #335328 30th Jun 2015 7:11pm
Check you have power at the connection the clutch engagement mechanism (the wires coming out of the compressor) should switch on with the ac. If you have power there then the clutch mechanism is duff. There is nothing that can't be fixed with a hammer😜😜
Post #335349 30th Jun 2015 8:34pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
There isn't a relay, it's fed from the A/C control unit directly.
As said above, check for power at the connector with the A/C engaged (you need to back probe the connector) then disconnect and check for resistance of the clutch coil to ground. It should be around 3 ohms. Outside of that then the wiring to the coil could be at fault or the clutch coil itself has gone.
Post #335426 1st Jul 2015 3:48pm
Glynn
Ive unplugged it and tested the voltage to it & its getting 9.4 volts.
So I put a 12 volt supply straight to it from the battery & nothing, the clutch won't engage.
Think its time for a new compressor.
What kind of price are they typically and how long to fit one ?.
Post #336986 12th Jul 2015 10:45am
