Home > General > For those that think a 5.0 SC is too expensive to run
Zirconblue
There is a difference between peak MPG and Average.
Average is affected by where you drive and your driving style.
Peak is easy to find out, just do a steady speed somewhere between 56mph and 70 then reset the trip computer. 56 is usually the optimum speed, i remember reading somewhere above that figure aerodynamics play a bigger part than weight, but it depends on the cars gearing. I did my 2004 4.4V8 at 65mph as at that speed the suspension lowers (should slightly reduce the frontal silhouette) it also puts the revs just over 2000rpm, which the book says is that engines most economical rev range (2-3000)
Average means less when comparing our cars on forums etc. Because i could drive my car along a given route then hand over to someone else and they could get a different figure, just because of their driving style.
it's why the whole EU drive cycle thing was introduced, because manufacturers would simply quote guesstimated figures, lie or pick the optimum fuel load, vehicle load, optimum and do it on a track with a slightly downhill slope when there was a tail wind and quote that. The figures you see in brochures now, give you a good like for like comparison between different cars, but the figure might not be exactly what you personally get from a car.
Post #331933 10th Jun 2015 8:55pm
Just done 2 days off roading in Wales, did about 620miles in total with the trip there and back and mine did 10.6mpg, mostly on petrol as they don't seem to use LPG in mid Wales...
Fully loaded, didn't hang about, lots of heavy bit's and 32" tyres....
That 10.6 is very accurate as my speedo is now just about spot on.... remember all other mpg's are based on speedo readings and will be about 10% high...
You don't buy one of these for economy.... Rolling with laughter Rolling with laughter Pete
Post #331949 10th Jun 2015 9:41pm
Nick Ground
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Indus Silver
I've just managed 32 mpg over a 270 mile trip on A-roads and motorways. The average speed was 63 mph so not a truck slipstreaming effort. The cruise control cannot match that figure.
Just to comment about the 'old' 56mph thing. It was a part of the EU test to run at a constant 90 kph to provide a comparison fuel economy figure. Never mind that it was on a rolling road with no air resistance etc. As a result car manufacturers modified the fuelling maps to make their vehicles to run very very lean air:fuel ratios at those exact revs. Hence most cars of that period are more economical at that speed. Of course the engine will be running less optimally too.
Nick 2019 D5 HSE Lux SDV6 Indus
55 D3 SE
98 MX5 1.8 RS
gone 17 older variants of FFRR
Post #331960 11th Jun 2015 6:20am
nemesisdazza
England 2012 Range Rover Autobiography 5.0 SC V8 Santorini Black
I was getting 2 MPG on Monday during my trip to Reading, was fun!
Post #331968 11th Jun 2015 8:02am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
EDIT ,that was after the M6 Toll, the one on my driveway was:
This was at the end of a 440 mile journey of drafting wagons at 56 MPH with no stopping from Home to Basinggrad and back. The lower figure was how much it dragged up the previous 12MPG reading from hooning around for a while- wanted to work out deltas to see how accurate it was tank to tank.
Laughing
Post #331971 11th Jun 2015 8:25am
Nick Ground
2 mpg is much more fun. Life is too short, although it feels the opposite, for 32mpg.
55 D3 SE
98 MX5 1.8 RS
Post #331976 11th Jun 2015 8:54am
Zirconblue
Nick
Ahh ok, that makes more sense now, as i wondered how a cars aerodynamics would all be the same at 56mph.
Cruise control is much like a manual gearbox vs. an automatic. In general cruise and an automatic will give better economy for the average member of the public. If you're a smooth driver though you can normally match and beat it going fully manual.
Post #332072 11th Jun 2015 5:13pm
