Home > Technical (L322) > 2013 Range Rover sdv8 autobiography trickle charger
mbdj
What's the best way to connect a trickle charger does this model have two batteries I can only find the one battery under the spare wheel Question
Post #329611 27th May 2015 12:20pm
IanT599
Ctek through the tow socket.
Adaptor is available on the forum shop for sale.
Post #329613 27th May 2015 12:29pm
I have a connector attached to the main battery and use that. You could also use the jump start connections under the bonnet.
There is a second battery in the side of the boot - where the indent area is you can pull away the side
Post #329615 27th May 2015 12:53pm
mbdj
I still have the ctek connector from my L322 but don't have the tow bar fitted to this car
Post #329620 27th May 2015 1:44pm
mbdj
So what's the best battery to connect to the one under the spare wheel or the one behind the side panel?
Post #329621 27th May 2015 1:47pm
I have no idea how they are actually connected, but my assumption is that the smaller one in the side panel is for accessories and the larger one under the spare is the starting battery.
I'm guessing that they are disconnected from each other when the ignition is off.
On that basis, I'd worry more about the one under the spare and charge that one first.
.... but I don't actually know
Post #329674 27th May 2015 7:38pm
Zirconblue
I don't really know either. But if you disconnect one, does the car still start? If you then reconnect it and disconnect the other one does the car start? That should tell you which one the starter battery is.
Post #329705 27th May 2015 9:57pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Starter battery is the big one.
Post #329755 28th May 2015 10:04am
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Get one of these they start with no lights on dash and last over 12 months with a charge there brilliant, i use for everything
http://www.ebay.co.uk/itm/DA1239-MULTI-FUN...3641.l6368 _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #329788 28th May 2015 1:01pm
