Home > Maintenance & Mods (L322) > Front rubber protection Bar
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Can anyone help with me finding fitting instructions for the front rubber Brush Bar. I have done a search with no luck
Post #328869 21st May 2015 9:34am
All accessory fitting guides are in Rave, you can download it from the Wiki....
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #328874 21st May 2015 9:58am
wayneg
I have Rave and have gone through all the sections with no luck, can you please advise on the section and page number.
I have found threads on other forums asking the same and answers suggest there are no instructions in Rave. There was a link to the LandRover website, owners info section but the link is dead.
I have just picked up a new bar with all unused fittings but no instructions. I understand that 4 holes need to be drilled through the bumper cover to expose threaded holes in the car frame. I have quite a few brackets within the kit I would like to find the correct assembly method for
You beat me to it, thanks
Post #328880 21st May 2015 10:56am
Zirconblue
it's on rave under accessory fitting instruction and it's also on Topix.
https://topix.landrover.jlrext.com/topix/c...oupId=1665
Post #328882 21st May 2015 11:00am
wayneg
My problem is I dont have a cd/dvd drive on my laptop so have to go through each pdf section. I still cannot find the fitting guides but I know what to look for now. The Topix link is perfect, downloaded what I need. Thanks for the help
Post #328893 21st May 2015 11:22am
Zirconblue
Just copy the entire contents of the Rave disc to a folder on your hard disc, then double click of 'tdata.exe' that should open up the rave interface. It's always worked on mine.
Post #328894 21st May 2015 11:32am
wayneg
I have downloaded rave as an iso disc image file and all good with a dvd drive emulator
Post #328907 21st May 2015 2:49pm
Zirconblue
unpack the iso file and copy the contents to a folder and it will work without the emulator. Wink
Post #328916 21st May 2015 3:59pm
psgk
I'm pretty sure you use to be able to download various accessory fitting instructions from the main LR site.
I have just found them but am getting an error message on my work station computer which may be due to our internal IT security systems
I have the Front Protection "A" Bar fitted to my MY2002 Vogue which I first had sprayed up in Body Colour (Java Black)
If you are really stuck I would be happy to search for the fitting instructions which I think I kept and pop a copy in the post to you if this would help Peter Kemp
Chelmsford
UNITED KINGDOM
Range Rover Vogue MY2002 4.4l V8
Java Black
Charcoal Trim / Oxford Seats
Colour Coded: Door Handles, All Badging Front and Rear, Bonnet Vent, Foam A-Bar / Nudge Bar
Range Rover Style 11 20'' Wheels
US Spec Front Sidelight / Indicator Light Units / Rear Light Units (MY2005 Style)
Retro Fit Sony / Alpine RES
Various LED Light upgraded Interior / Exterior
Lower Rear Tailgate Gas Strut modification
Post #329044 22nd May 2015 12:28pm
Zirconblue
You still can I posted the link to Topix above.
Post #329079 22nd May 2015 6:02pm
