Home > Technical (L322) > P0314-01 Fault Code and Live Test Values
Discotigger
Been getting a shaking at idle on my TD6, so put the IID Tool on this afternoon.
Got the following fault code from the engine ECU
P0314-01 Cylinder Balance Control - l - Component Deviation outside limit
Cleared the fault and checked the live values on the engine. Went into Fuel Comp and got the following values for the cylinders:
Cyl 1: -2 mm3 Cyl 2: +7 mm3 Cyl 3: -2 mm3 Cyl 4: -4 mm3 Cyl 5: -3 mm3 Cyl 6: -1 mm3
Seems something is out with Cylinder 2, but what does 'Fuel Comp' refer to, and what are the values referring to?
Any help would be greatly appreciated.
Post #325394 1st May 2015 5:06pm
Mikey
Cylinder 2 is massively over fuelling, causing your misfire Thumbs Up
Most likely to be an injector at fault, but in some cases, the wiring harness gives similar symptoms.
It could also be a mechanical issue on that cylinder, but this is highly unlikely Thumbs Up
Post #325399 1st May 2015 5:25pm
Discotigger
Cheers for that info, much appreciated. Thumbs Up
Thought maybe injector fault, but couldn't work out what the + and - values represented and what the 'Fuel Comp' meant.
Will have to get it into my local indy to get checked out, I know wiring looms are relatively cheap, if it's an injector I can probably get a good second hand /refurbed one from the fleabay.
Post #325435 1st May 2015 7:55pm
Mikey
Anything over +2 is bad...
Recon injectors can be had for £150 or so. Wouldnt take the chance on a 2nd hand one...
Post #325437 1st May 2015 8:11pm
Take two injectors out and swap them around... If the fault moves you know its an injector... If it stays its either wiring or mechanical (probably wiring loom related though!
Post #325494 2nd May 2015 7:56am
Discotigger
Many thanks for the replies and suggestions guys. Bow down Bow down
I'll be getting the FF into my indy to look over it, so will give them the info as it will save time and money. Thumbs Up
Checked on fleabay and can get either the wiring loom or a warrantied injector, so will at least be able to get it sorted without too much cost...I hope!
Post #325543 2nd May 2015 2:51pm
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi what was the outcome as I have the same issue and fault codes at the minute.
Cheers
J Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #519532 24th Jun 2019 2:43pm
