Home > Technical (L322) > Sitting square
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Sitting square
Looking at my car today, I feel that it is sitting down on the nearside by about 1-2 inches! Can you lift the rear suspension one spring at a time???
Thank you 2014 vogue se
Post #322491 13th Apr 2015 9:16pm
johnboyairey
You may have a broken height sensor, each wheel has one. So four on the car...or even just a malfunctioning one. You can check if there is any damage by inspecting them with a wheel off, one at a time. They have a thin arm coming from them and these can break of come off or the sensor could be corroded inside. -it thinks it's set right, but it looks wrong. Maybe do some searches on here for height sensors.
Post #322493 13th Apr 2015 9:26pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
I'm not sure but is it not possible to reset them by turning the steering all the way right then all the way left lock to lock?
Don't try it until someone else confirms cuz this may be a way of telling the car to store the current heights etc.
Just a thought.
Posssible leak? does it drop over time or level at all on the move? 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #322499 13th Apr 2015 9:59pm
Suspension may need calibration if always a bit low on one side. Diagnostic tool, tape measure and some level ground.
If car goes wonky after having been left a while, on level ground, then it is either the sensors (car does some leveling even when shut down) or you have a leak in one of the bags. Find leak by taking car to off road height, then lift each wheelarch and listen for hissing, or do the soapy water test on the air bags.
Sometimes, no amount of fixing and fiddling will sort it (I have a lower LF than RF) and even with new airbag unable to get things level. That said, sometimes it appears to sort itself out! .
Post #322504 13th Apr 2015 10:46pm
The crazy world of Range Rover Whistle Whistle Whistle Thumbs Up
Post #322505 13th Apr 2015 10:59pm
chefkenmore
Thanks for the answers, shall check next week when it returns after full wheel refurb, and front bumper and inner sill respray!!
Had enough of airbags with the D2!!! Great system tho...........................
Thumbs Up Thumbs Up Thumbs Up 2014 vogue se
Post #322527 14th Apr 2015 8:23am
