Home > Maintenance & Mods (L322) > Trying to remove offside headlight to replace wiper motor |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8192 |
Here you go, from Rave
7th Apr 2015 3:28pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35279 |
plenty soaking of WD40 and hopefully that bolt will undo.. ... - .- -.
7th Apr 2015 3:34pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
PlusGas would be even better. John
7th Apr 2015 3:47pm |
Zambezi Member Since: 07 Feb 2015 Location: Bury St Edmunds, Suffolk Posts: 67 |
Thanks for the information.
7th Apr 2015 4:49pm |
7th Apr 2015 4:54pm |
Hi Stan. Yes I've seen that and used it to replace the glass on my nearside light but this time I'm looking at the offside headlight and as it states in the video, the offside is much harder...especially when the difficult to get at bolt is seized.....joy ! |
7th Apr 2015 4:58pm |
ah ok, once you get that bolt undone it shouldnt be to difficult.. ... - .- -.
7th Apr 2015 5:01pm |
Ianmaney Member Since: 27 Nov 2012 Location: Birmingham UK Posts: 118 |
I ended up drilling mine out and using an alternate fixing Semper in merda sumus, solum altum variat !!
7th Apr 2015 5:12pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
If you turn it hard enough it should break the much weaker bolt fixing below. Simple replace with another suitable nut and bolt. Support the plastic mounting point though otherwise this may snap off. See here http://www.fullfatrr.com/gallery/thumbnails.php?album=466 .
7th Apr 2015 10:34pm |
Thanks for everyone's advice. After soaking in penetrating fluid overnight, the bolt came out with the use of a 1/4 inch socket set with seemed to grip the bolt (8mm head) much better than my 1/2 inch socket set.
10th Apr 2015 3:49pm |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 790 |
Was in that area the other day to remove headlight. The same bolt that gave you trouble snapped clean off as soon as I put my socket on it and attempted to turn it. A lot quicker than soaking with penetrating oil ! |
10th Apr 2015 5:53pm |
As long as you've got some of the captive nuts to replace it....
10th Apr 2015 6:04pm |
