Home > In Car Electronics (L322) > Replacement reversing camera
dmb7
United Kingdom 2006 Range Rover Vogue Td6 Santorini Black
I have a late 2006 Vogue with touch screen, my reversing camera is damaged and needs replacing. Does anybody know what the replacement code is. I understand that a camera off a 2010 model is an updated version but no sure if it's a straight swap LR031812 ?
Post #319662 25th Mar 2015 8:49pm
according to microcat there are 2 depending on vin,
XVI500120PNP CAMERA, MOUNTS IN SPOILER, REAR VIEW CAMERA-FIXED (V)6A000001 (V)6A216969
XVI500180PNP CAMERA, MOUNTS IN SPOILER, REAR VIEW CAMERA-FIXED (V)6A216970
don't know if the 2010 -> camera will fit, but i doubt it...... There is nothing that can't be fixed with a hammer๐Ÿ˜œ๐Ÿ˜œ
Post #319672 25th Mar 2015 9:17pm
dmb7
Thanks. My vin is non of those?
Post #319678 25th Mar 2015 9:54pm
they are vin ranges, (V)6A000001 to (V)6A216969 then(V)6A216970 on to 9A999999
doesn't list a camera for pre these vins..... There is nothing that can't be fixed with a hammer๐Ÿ˜œ๐Ÿ˜œ
Post #319679 25th Mar 2015 9:59pm
dmb7
Thanks for the info. Wow they are expensive!
Post #319688 25th Mar 2015 11:12pm
have a look in the wiki and do a search, theres loads on this.. Thumbs Up ... - .- -.
Post #319720 26th Mar 2015 8:46am
dmb7
Thanks tried a search and got nothing?
Post #319859 26th Mar 2015 6:09pm
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
Bought one off ebay, 15 €
Tested it and works great, but when I was pulling the cables to finish the job, one of them snapped Big Cry
I had to buy another, so it'll be fitting time this weekend.
All in all, 30€ for a camera.
Better off than the 700+ they charge you for an original Shocked
Post #320019 27th Mar 2015 12:50pm
dmb7
Thanks for the message. Can you tell me what the camera is that you bought ?
Post #320025 27th Mar 2015 1:12pm
VMPP
One of these:
http://www.ebay.co.uk/itm/231390415722?_tr...EBIDX%3AIT
The image seems perfectly fine.
I'm leaving active the option that they have to have guide lines (even though they don't move, they look nice)
I tried to fit the camera inside the original housing, and it fits ok, but in the end I think that the job is not clean enough (I'm not that handy), and as the camera goes under the spoiler, I will just fit it on its own.
Post #320082 27th Mar 2015 6:37pm
dmb7
Thanks. Do you connect to existing wires or rewire?
Post #320090 27th Mar 2015 7:00pm
VMPP
You need to chop and connect them.
You can chop them before the plugs and use the existent plugs.
I stripped the power wires before the power plugs.
The video, I made a mistake and chopped it after the plug, so I had to do a direct connection.
The image is Ok, not hidef, but ok.
At night, compared to the original, which was very dark, this one is very bright.
Post #320333 29th Mar 2015 3:22pm
