Home > Maintenance & Mods (L322) > The Best Fuel System Cleaner is BG44K ? |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Me and my business partner bought our 4.2's at the same time, his suffered from this issue early on and was 'updated', mine did it after about 50,000 miles and again, it was updated. I seem to recall it was something to do with fuel grade, are you using standard fuel or the 'super' fuel? I was advised to stick with 95 RON (I think that was it as it was a while ago). Land Rover Addict
21st Feb 2015 8:01pm |
Thanks again DMRR.
21st Feb 2015 8:06pm |
I think the RON rating for that is too high - it is ok to run on it now and again but the main diet should be standard unleaded, that's what the UK spec ECU is expecting, 95 RON Land Rover Addict
21st Feb 2015 8:11pm |
There you are then and I thought liquid gold was the way to do it.
21st Feb 2015 8:24pm |
Standard in the UK being premium (95), standard everywhere else is 91...... and called 'unleaded' - nightmare!!! Land Rover Addict
21st Feb 2015 8:29pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8501 |
Interesting that ^
21st Feb 2015 9:41pm |
It suggests that the SC doesn't need tank after tank of 99 RON + of Shell VPower Nitro +
21st Feb 2015 10:43pm |
Regular shell fuel save unleaded should do it then, wonder if it is the same for disesel There is nothing that can't be fixed with a hammer😜😜
21st Feb 2015 10:49pm |
4 weeks since putting BG in the tank and 3 weeks since converting from Shell V Power Nitro+ to Shell Save (standard) unleaded and the system too rich, system too lean warnings have gone.
15th Mar 2015 8:53am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3777 |
I got a gallon of this stuff for my Diesel but kept forgetting to put it in, didnt seem to make any difference for me. I only bought it after reading a thread on here, I just get Tescos cheapest now just as I have been doing for the last 20 odd years with no problem - just lucky I guess Geoff |
15th Mar 2015 9:05am |
I only tried BG after researching around the rich and lean warnings, hoping it might banish the warnings along with a MAF sensor clean and changing to standard fuel. |
15th Mar 2015 9:14am |
