Home > Technical (L322) > coolant
Garyfax
England 2009 Range Rover Vogue SE TDV8 Santorini Black
coolant
silly question maybe but best to check.
My 3.6 V8 is asking for coolant, is it just water or something special it has some red solution inl?
Regards Gary
Post #316688 7th Mar 2015 8:59am
no its not just water, needs a 50:50 mix of pink coolant and water adding to the header tank.
it shouldn't need coolant adding as a matter of course so check the visual levels when cold and see if its in the cold fill range.
Have you had anything attached to the cooling system replaced recently, as the system can take a while to bleed through and the level will keep dropping until all the air is out of the system.
If the level seems ok then its possible the level sensor is duff. If it is low then check for leaks, there are a few hoses which are susceptible to wear under the header, and can start to bleed off fluid, they can be easily changed but they are only available as part of the entire hose assembly......
If it needs topping up a small amount then a tub of ready mix pink coolant from halfords will do the job. There is nothing that can't be fixed with a hammer😜😜
Post #316711 7th Mar 2015 11:00am
Garyfax
Thanks. I bought some antifreeze and topped it up today, it only took about 1/4 pint so maybe its the sensor. I will keep an eye on it. thanks for your help.
Post #316756 7th Mar 2015 6:48pm
billcyn
United Kingdom 2008 Range Rover Vogue TDV8 Epsom Green
Just replaced my coolant header tank c/w sensor after being driven nuts with "check coolant level" bongs.
Straightforward job (2 bolts & 2 hoses plus sensor connector) at total cost of £35 & no more bongs'
Post #316765 7th Mar 2015 8:18pm
Ziggy
Australia
I might be wrong but I am sure (I think) that sounds a bit daft......never mind back to what i think I may be sure about
Right,coolant warnings. don't they give a warning when the coolant goes out of spec? so you might not need any more fluid in but a complete drain and re-fill with the right % of coolant and water
As I said I could be wrong
Ziggy "Those who cannot remember the past are condemned to repeat it."
George Santayana
Puts away his cloth cap and donkey jacket
Goes and sits in the naughty corner
Post #316794 7th Mar 2015 10:43pm
billcyn
As northernmonkeyjones said, you need a 50:50 mix of PINK antifreeze & water. This can be checked
with a antifreeze/coolant tester eg Gunson. Some say that the sensor checks the SG (specific gravity) of the coolant mix & will warn if this is out of limits - I am yet to be convinced, but no doubt someone on the forum will provide a definitive answer. After installing a new header tank/sensor, have had no further problems using existing coolant mix.
Post #316799 7th Mar 2015 10:56pm
Yes they do Ziggy Thumbs Up
Post #316804 7th Mar 2015 11:28pm
Ziggy
Australia
Thank you sir, I thought they did but was not positive very clever motors these
George Santayana
Post #316832 8th Mar 2015 8:39am
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
Why is the color so important? Is blue not good for the RR?
Post #316969 8th Mar 2015 7:51pm
Weegie
As I understand it, pink is longlife - 5 years whereas blue is only 2 years. If you mix them it reduces the pink to 2 years.
It used to be said that blue was unsuitable for engines with alloys. Don't know how true that is now. John
GAP iiD BT
Post #316971 8th Mar 2015 7:54pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Pink coolant every four years regardless of mileage. According to wiki.
Post #316979 8th Mar 2015 8:21pm
Depends on the engine chaps.
Afaik the tdv8 is pink and the td6 Is blue.
Different base for the coolant, pink is chemically different from blue, and never the twain shall mix! There is nothing that can't be fixed with a hammer😜😜
Post #316997 8th Mar 2015 9:15pm
gregdav
Yeh don't mix. But my td6 definitely pink. Thumbs Up
Post #317001 8th Mar 2015 9:25pm
Strange that cos both my Bmw 3.0 diesels were blue?
Weird. There is nothing that can't be fixed with a hammer😜😜
Post #317005 8th Mar 2015 9:32pm
gregdav
Hmmmm does state in wiki longlife coolent. I always assumed that was the pink oat stuff every five years and blue every two years. But mines definitely pink. Thumbs Up
Post #317008 8th Mar 2015 9:45pm
