Home > In Car Electronics (L322) > touchscreen unit not dimming at night..
JPS
2005 Range Rover Autobiography Td6 Zambezi Silver
Is the touchscreen on my Range Rover meant to dim when I put my headlights on or its dark? As it doesn't and seems very bright. Any ideas how I can fix this.. Many thanks [/i]
Post #297776 8th Dec 2014 7:36pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
On earlier non touchscreen it does dim and the colour scheme changes as well.
Look in the menu, it is possible the previous owner had the day and night settings set the same.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #297787 8th Dec 2014 8:06pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Try changing it under screen settings. I think there are two settings as above, have had a play myself as screen a little bright at night. Unless you really need it you may turn it off altogether. Found a lot of settings on there reset once you turn off and back on again. Still learning myself.
best of luck Thumbs Up
greg
Post #297860 9th Dec 2014 7:35am
JPS
Thanks guys I will give this a try tonight and see how I go
Post #297903 9th Dec 2014 12:50pm
never done it so not sure but i think its brightness can be dimmed using the dash light dimmer by the headlight switch... ... - .- -.
Post #297905 9th Dec 2014 1:04pm
Doesn't auto dim, but can be dimmed Or to turn it off, press and hold the voice command button on the steering wheel, and say "display off"
Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #297978 9th Dec 2014 6:46pm
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
My late 05 touch screen does dim (sometimes!) When working it dims / brightens during the day (for example sunny day going into shade it brightens) However 50% of the time it does neither and I have it turned down to minimum brightness - the brightness nob (oh-er) does change it as well but only by a small amount. Noticed when it's working at night, turning the lights on does make it dimer.
I've checked for fault codes and can't find anything obvious ..
as per other posts posts I turn the dam thing off when it annoys Smile
Cheers
RP
Post #297991 9th Dec 2014 8:32pm
there is a light sensor [number 12] and it could possibly be blocked with dirt ,
Post #297993 9th Dec 2014 8:47pm
You beat me to it Stan... The unit has a low light sensor which takes a good few seconds (often 30secs) to dim the unit... Thumbs Up
Post #297994 9th Dec 2014 8:53pm
That's a new one on me, still really bright at night on mine😢, I end up turning it off most of the time, much prefer driving with it off as its much less distracting. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #297998 9th Dec 2014 9:02pm
For night driving I find the voice controls really help , no rummaging through nav menus just press the button an " navigation screen off" and bask in the cool green glow of waterfall lighting , it really looks good without the big screen glow and very restful. 2008 MY Supercharged
Post #298040 10th Dec 2014 1:25am
IIRC in the menus you can set how bright it is at night, also try it by turning the vehicle lights on from auto and seeing if it dims then Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #298104 10th Dec 2014 10:41am
JPS
Thanks guys this is a big help and off to check my sensor now Thumbs Up
Post #298341 11th Dec 2014 12:15pm
