Home > Technical (L322) > CROSS ARTICULATION FAULT
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
BONG...Slow down to 30 MPH Suspension Fault
Car dropped to bump stops and Terrain Response / Suspension button lights went off
IID tool says "Cross Articulation Fault" C1A07-62 (no other faults logged )
Turned ignition off and on, all fine / reset ....until i go over 30 MPH then same again.
Any thoughts on what Cross Articulation Fault covers?
PM2 GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #292721 13th Nov 2014 1:03pm
has a sensor popped off? Pete
Post #292723 13th Nov 2014 1:05pm
Mikey
Incorrect readings from the height sensors.
Could be an incorrect calibration, or sensor/wiring at fault
Watch the live data as the car goes up and down. They should all move a similar amount, and at the same rate
Check your tyre pressures too, a soft tyre causes the car to lean, and can bring up the same fault
Post #292725 13th Nov 2014 1:06pm
paulmoran2
They all looked good when I did the front and rear pads a couple of days ago GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #292727 13th Nov 2014 1:07pm
http://www.lrrforums.com/showthread.php?18...tops/page4
or
http://www.fullfatrr.com/forum/topic14741.html?view=previous Got - 2017 SDV8 Autobiography in Loire Blue
Post #292729 13th Nov 2014 1:07pm
paulmoran2
Cheers Mikey...I did adjustments back to my standard height following a green laning day, so wonder if i've Censored up the calibration somehow.
The RL and RR are very different 220 and 150... GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #292730 13th Nov 2014 1:09pm
paulmoran2
Cheers Alan...seen those following a google search, but they all seem to have multiple fault codes, whereas I just have the one? GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #292731 13th Nov 2014 1:12pm
Mikey
Your issue lies in one of those sensors, or respective wiring. The car thinks there is a 70mm difference across the axle, best part of 3 inches, so the car dumps itself down, effectively in suspension "limp mode"
Start with a calibration Thumbs Up
Post #292733 13th Nov 2014 1:24pm
paulmoran2
Cheers Mikey...Thought it might be my fault Rolling Eyes GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #292743 13th Nov 2014 1:43pm
Mikey
I done the same with my Disco 3 after playing with the corner heights Wink
Post #292745 13th Nov 2014 1:49pm
Leave well alone all......
Post #292774 13th Nov 2014 3:55pm
Not too sure exactly what the sensors are like but I've messed with my heights loads... at first it was a bit finicky and kept throwing up codes and I came to the conclusion it was because although they have a wide range of movement they usually just move a small amount... I took all the rods off and moved the sensor through it's whole movement numerous times, they certainly had more resistance at the ends of their movement, cleaned the electrical connectors and put them back together and not had a problem since... Might be worth a go....
(I really shouldn't have said that.... you can guess what fault I'm getting tomorrow???!!?!?) Pete
Post #292790 13th Nov 2014 5:39pm
paulmoran2
Had a play this evening and all sorted...As Mikey said, the difference between the rear left and rear right seemed to be the issue.
Cheers for your help guys Thumbs Up GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #292820 13th Nov 2014 8:23pm
miggit
Most height sensors are nothing more than a potentiometer which is a little arm that rubs up and down a carbon track, over the years as the ride height changes, these ware out, quicker now a days with our roads! As they ware out you get false readings from them and the computer overcompensates, until it shuts down, and you get that sinking feeling!
I haven't had to play with these yet but, I imagine that with a multi meter set to ohm's you should be able to see the resistance going up and down smoothly as they are moved, if you don't see a smooth reading from top to bottom of the height sensors travel, I would suspect that it is duff, no more for this coil and destined for the dump!
If you've ever had an old amplifier that crackles when you adjust the volume, that is what the suspension computers listening to, no wonder that it's got it wrong! Yesterday I couldn't spell Engineer... Today I are one!
Post #292836 13th Nov 2014 10:16pm
trainmanone
England 2002 Range Rover HSE Td6 Oslo Blue
sorry to highjack the thread but I have an issue with a height sensor ,according to hawkeye rear left sensor not working. Question is it left from drivers seat or left looking from front of car????? have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #293141 15th Nov 2014 10:35am
