Home > Technical (L322) > Heater-trouble-Warm on idle, cold driving. 140 cap to blame? |
MariusRR Member Since: 19 Mar 2013 Location: Oslo Posts: 98 |
Anyone? |
22nd Sep 2014 10:35am |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
I am no expert on the l322 cooling system but spent many hours fiddling with the p38 cooling system and from what you describe my guess is you could have an air lock. The BMW engine is a real pig to get all the air out of. There is also a secondary pump in the system and I am led to believe that the header tank can suffer from hairline cracks that only show when engine is really hot and under pressure - also with replacing the cap on the header tank ?
22nd Sep 2014 11:38am |
Sandy could be right about the air-lock since all engines (also the later 4.2 SC engine) are quite difficult to fill after empty (mine has been done twice due to two oil/coolant heat exchangers failing).
22nd Sep 2014 11:44am |
I will try and bleed it some more then!
23rd Sep 2014 7:55am |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
I'm losing coolant to the point where the electric fan is coming on. I've pressure tested the system using a Blue Point testing kit and also checked for gases in the coolant but all is fine.
24th Sep 2014 10:40am |
On my car there was a leak underneath. A gasket on the gearbox or converter. Didn`t show a leak on the pressuretest, but it you touched it with your hands it poured out. Might be worth a check og search on the forum.
24th Sep 2014 1:04pm |
Update.
19th Oct 2014 6:18pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8192 |
Has it got LPG ?? Pete
19th Oct 2014 7:29pm |
No LPG no |
19th Oct 2014 8:14pm |
Oh right, can't help then unfortunately, sometimes if the LPG vaporiser water pipes are fitted wrong they will starve the heater... Pete
19th Oct 2014 8:34pm |
Have you checked the actual temperature of the heater itself. It would mean getting to it but it may be worth pulling the das apart for that. Then also check the flaps if they are moving in the right direction.
20th Oct 2014 1:43am |
Faulty thermostat? |
20th Oct 2014 6:17am |
Car got a new thermostat in march so doubt its that! |
20th Oct 2014 8:48am |
Another quick question.
20th Oct 2014 11:36am |
