Home > Maintenance & Mods (L322) > Front Disks / Brake Judder |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
FYI those bolts are only done up to 84 ft/lbs (if my memory isn't failing me, be gentle) , which is alot less that the wheel nuts at 103 ft/lbs, and mine showed no signs of stud lock. I did have to yank the bar to break them free, but int wasn't more than an 1/8 of a turn before they gave the good old crank and let go.
4th Oct 2014 2:57pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
84lb ft = 114nm
4th Oct 2014 3:58pm |
They don't have thread glue on them do they, in which case a bit of heat first (well away from the brake fluid)? |
4th Oct 2014 4:02pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7796 |
Not sure. They looked pretty corroded. Looks like they have not been undone in ages.
4th Oct 2014 4:25pm |
A butane/propane torch would be enough to melt thread glue.
4th Oct 2014 4:40pm |
I NEEEEED one Will pick one up the next time I'm in the UK. MY 2010 5.0 SC Galway green and sand interior!! Have the Faultmate MSV2 Extreme to be tinkering with the settings etc. !! |
5th Oct 2014 3:38am |
Hi chaps, just a couple of points
Did you turn the wheel to move the calliper away from the car? Cos if ya didn't no wonder you was having stress! With the wheel turned it is possible to get over an eighth of a turn on a breaker bar before the wing gets in the way
You can get these on Fleabay from all over the world Yesterday I couldn't spell Engineer... Today I are one! Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
5th Oct 2014 10:08am |
Well, brakes all done.
7th Oct 2014 8:21pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8195 |
Glad it's sorted Mark, sounds like it's never been off before.... you need to drive faster.... and brake later.... Pete
7th Oct 2014 9:07pm |
