![]() | Home > Technical (L322) > Pre heat |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 ![]() ![]() ![]() |
Had a quick look on my phone which is difficult .......why the tears ? |
Paul do you have the PDF for the T90 as that's what mine is I believe?
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
J evro..Tears cos its not working for you
The Webasto Fuel Burning Heater T90 / T91 are used in many different makes / models, so the "fuse" is fitted on many, but is also a generic term for "pulling the power " to the receiver unit , which is something we can do on the FF by pulling the plug out .
Ok thanks, I just thought maybe this 1A fuse may have been the issue but couldn't see it inline, one thing I am not is electric minded so do I just get a meter and poke it down the plug holes with the 3 wires |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2275 ![]() ![]() ![]() |
Same remote as I have for mine albeit mine is a petrol (not the remote it has a battery ) ![]() |
Haha. Yeah might be less bother if it was petrol driven like a Zippo eh! |
J evro...basically yes...Set your multi meter to 20v-dc and touch the black probe to a good chassis point, then touch the red probe on each of the three wires..one of them should show 12v.
Multimeter..multimeter indeed what the |
The strangest thing...
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
My 10MY has the T91 telestart unit, i followed this after changing the remote battery, worked a treat:
Me again!.......it's 10degrees here so thought I would try my FBH this time I set it up on the touchscreen timer and system started up at the requested time but it turned back off after only 2 minutes? The heater unit under the battery in engine compartment on passenger side continued to whirr away for a further 2 minutes but at no time did any warm/hot air come out of the interior vents?, Any ideas? |
its either not getting fuel or not igniting the fuel it is getting Cheers
Hmm no idea if/ when the previous owner used it last , is there a way to see if it is igniting ? |
