Home > Technical (L322) > Pre heat
Page 1 of 4 1234>
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Pre heat
Hi all,
Newbie question.......Trying to get the pre heater working from the remote ,
I see it says
Constant LED on means system working programme
Three LED flashes - programme not working,
Every time I try it flashes 6/7 times but I cannot find an explanation what this means .....any ideas?
Post #278679 2nd Sep 2014 5:29pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Hi j evro
handbook says it has to be a certain temp outside before it kicks in.
hav'nt tried mine yet. waiting for temps to drop a bit more.
I may be wrong but i'm sure someone else will verify.
greg
Post #278727 2nd Sep 2014 9:54pm
Discotigger
It could also mean your battery is knackered, the one in the remote fob that is. May be worthwhile getting a new fob battery and doing the remote fob pairing sequence again.
Post #278730 2nd Sep 2014 10:04pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Pairing sequence in case you need it>>
You find the Webasto FBH receiver in the back right compartment it's behind the fuse panel (marked with a black outline on the photo) you can unbolt this by removing the 3 marked hex head screws>
The panel can normally be turned / angled so that you can access its rear without unplugging any panel connectors as the looms are long enough.
You can then see a black box mounted onto the back of this panel. You should find the FBH receiver and power lead here.
Once you have accessed the receiver just pull the power lead and press the buttons within ten-seconds as per the instructions below >
1- Insert Battery into the battery compartment of the remote fob
2- Remove power lead from receiver – Wait 5 seconds at least and re-plug in power lead into receiver
3- After approx 2 seconds, but within 6 seconds, press the OFF button on the key fob for at least 1 second
4- Teaching is now complete.
5- Maximum of 4 transmitters can be coded in this way.
Have fun.
Paul GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #278769 3rd Sep 2014 7:54am
J evro
Excellent guys thanks will try above when I get back with the car
This forum is proving invaluable already for a new owner like myself
Bow down Bow down Bow down
Post #278888 3rd Sep 2014 5:28pm
J evro
Hmmm!
Renewed the fob batteries , Tried above reset sequence as above several times but still flashing 6-7 times on fob and no start up,
There are 2 connections on back of the unit ....1 is a single wire and one is a 3 wire connector , I only tried the single wire one as per (poor I know as I was holding upside down)...picture as could not undo the 3 wire connector one and was afraid I would snap it off (how do you undo these?)
Post #280424 11th Sep 2014 3:25pm
J evro
Unnecessary quote removed
Tried that paul with no success , I pulled the single wire ( not the 3 wire connector ) was that correct ?, also had key off ...
Post #280751 13th Sep 2014 4:35pm
paulmoran2
The single is the antenna...try the triple wired connector..the receiver is permanently powered , so the key doesnt need to be in IIRC.
Post #280757 13th Sep 2014 4:52pm
J evro
Cheers , tried to remove the 3 wire one but couldn't budge it ....how do they come off ? ....I don't want to snap it , I'm prone to that Thumbs Up
Post #280760 13th Sep 2014 5:25pm
paulmoran2
I'll have a look tomorrow and report back Thumbs Up GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #280774 13th Sep 2014 6:50pm
J evro
Appreciated Thumbs Up
Post #280799 13th Sep 2014 7:38pm
paulmoran2
J evro...you just pull it off (there arn't any clips to push in or undo etc but it is very stiff ). If you remove the receiver from the back plate by removing the 2 black plastic hex nuts, then its easier as you can get a good grip of the plug (obviously not the wires) then simply pull / wiggle it straight out. Just done it just now with the ignition key not in.
Post #280921 14th Sep 2014 3:03pm
J evro
Paul,
Your a gentleman really appreciate your time thanks, will try this again when I'm home Thumbs Up
Post #280924 14th Sep 2014 3:09pm
J evro
Okay... Removed the 3 wire 'plug' / followed sequence as above , renewed fob batteries, .... Censored fob still flashing 8 times green for on and 8 times red when I press off...
I have trawled for hours to try and find something on this but failed so far ...
Trying to get a video up to show fob LEDs but cannot seem to do it on here via normal photo way?
Post #280933 14th Sep 2014 3:47pm
paulmoran2
J evro... Big Cry
Have a read of this PDF from Webasto>>
http://www.webasto.com/fileadmin/webasto_f...rt-t91.pdf
and / or PM me your mobile number, if you need to discuss.
Post #280937 14th Sep 2014 4:18pm
Page 1 of 4 1234>
