![]() | Home > Technical (L322) > Pre heat |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Hi j evro
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
It could also mean your battery is knackered, the one in the remote fob that is. May be worthwhile getting a new fob battery and doing the remote fob pairing sequence again. |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Pairing sequence in case you need it>>
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 ![]() ![]() ![]() |
Excellent guys thanks will try above when I get back with the car
Hmmm!
Unnecessary quote removed
The single is the antenna...try the triple wired connector..the receiver is permanently powered , so the key doesnt need to be in IIRC.
Cheers , tried to remove the 3 wire one but couldn't budge it ....how do they come off ? ....I don't want to snap it , I'm prone to that |
I'll have a look tomorrow and report back |
Appreciated |
J evro...you just pull it off (there arn't any clips to push in or undo etc but it is very stiff ). If you remove the receiver from the back plate by removing the 2 black plastic hex nuts, then its easier as you can get a good grip of the plug (obviously not the wires) then simply pull / wiggle it straight out. Just done it just now with the ignition key not in.
Paul,
Okay... Removed the 3 wire 'plug' / followed sequence as above , renewed fob batteries, .... |
J evro... |
