Home > Technical (L322) > whistling noise |
shalz Member Since: 28 Jan 2013 Location: where FFRRs roam free...! Posts: 503 |
Also, apparently where the m25 meets the m1, there is a permanent smell in the area like , I can't remember where I was before I turned on the ac and got the smell but that's one theory I heard this evening for the awful smell in the cabin...
21st Jul 2014 12:27am |
Drove mine home and hit motorways speeds - whistling noise gone. I'm going to just be happy this is gone and not try to tempt fate by not investigating further. Smell has also gone.
21st Jul 2014 6:20pm |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 |
There was a thread where a bearing in the air con unit melts and causes a whistle noise ? Is this where I put the car details and a bit about myself ?........ |
21st Jul 2014 9:11pm |
whoami Member Since: 04 Dec 2009 Location: UK Posts: 76 |
New heater box arrived at dealer this morning. It's a whole dash out job (apparently) so we were told not to expect the car back until after the weekend.
23rd Jul 2014 2:56pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
when you get it back just put a bit of pressure on different parts of the dash and listen for squeaks they are a to get all the soundproofing right but can be done |
23rd Jul 2014 6:33pm |
Getting it back tomorrow and am dreading listening out for squeaks and rattles.
27th Jul 2014 12:49pm |
As you predicted, we've now got a nice vibration/buzz from the middle of the dash. |
29th Jul 2014 2:38pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35274 |
there are some star shaped screws on top of the dash that do get loose, might be worth tightening those.. ... - .- -.
29th Jul 2014 2:40pm |
mikef Member Since: 30 Jan 2013 Location: Bucks Posts: 82 |
Me too on my 2011 TDV8. I have 2 problems with the climate control, the whistling noise at speed as described by others and on occasions no air coming through any of the front vents. The whistling noise seems to have something to do with the air recirculation system because switching that off usually cures it. The lack of air can usually be cured by switching the max aircon switch on for a few seconds although recently that sometimes doesn't work.
1st Aug 2014 8:58pm |
Well, after a further 4 weeks in the dealer, I was told it had been fixed.
15th Dec 2014 9:02pm |
Any ideas? |
16th Dec 2014 8:27pm |
FrankRizzo Member Since: 27 Aug 2012 Location: Frankfurt am Main Posts: 214 |
Thought I'd revive this thread to add my two cents. Had my 12MY Vogue for about 3 months now and noticed that the air con whistles at speeds above 87mph/140kph even when the system is off. The whistle continues after switching the air con on until the the next time that it sucks in more air (that occasional short noise you hear that sounds like air being sucked in). After that the whistle is gone.
16th Sep 2017 11:18am |
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 259 |
Yep, mine whistles too when going over about 30 mph. Only way I've found to stop it is to close the driver's side vent adjuster wheel fully.
16th Sep 2017 11:40am |
Edward2595 Member Since: 09 Oct 2017 Location: Lincoln City, Oregon Posts: 1 |
It's the ram air door and re-circulation that is causing this. I"m not sure exactly why but it could be they are not resetting. Check out the climate control description and operation in the land rover workshop manual. Specifically look at ram air door operation and you'll see the correlation between speeds and how much they are open and closing during specific speeds and this noise 30/60/90 kmh respectively. I don't know how to post the pdf for this or I would. |
1st Nov 2017 5:10pm |
