Home > Technical (L322) > Very Poorly FF!!! |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6723 |
I'd go with a duff battery Got - 2017 SDV8 Autobiography in Loire Blue
7th Jul 2014 4:04pm |
Benfelrr Member Since: 27 May 2012 Location: Wiltshire Posts: 297 |
My car's ignition / steering lock ECU has just failed and I am pretty sure the garage said there were fault codes logged, so hopefully if it is a steering lock ECU problem it wont be too difficult to identify. I sincerely hope for you it is not the steering lock / ignition / immobilisation ECU as my bill is going to be over £3,000.00 .
7th Jul 2014 4:12pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Did you/have you tried a battery reset? |
7th Jul 2014 5:19pm |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 |
Yes Craig, having seen a lot of posts on here over the last few months, I did follow the battery disconnection procedure, shorted out the battery leads, and then re-connected the battery, (prior to calling out the AA on saturday), unfortunately didn't change anything.
7th Jul 2014 5:56pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
Sounds battery Ray, borrow mine to see if it helps, I have a spare one just firing the electric fence. If it dont work.......burn it!
7th Jul 2014 7:49pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2575 |
Ray, may or may not be of use, I had a similar issue a couple of years back which after a shed load of toing anfd froing turned out to be the instrument cluster, had all power to car, lights etc but unusual messages, had to be done at a stealer (may have changed now), was about £1000, as an aside the stealer engineer remarked to my Indy who picked it up that it was 'only fit for the scrappy'...... nice |
7th Jul 2014 8:00pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8192 |
Mine did very similar.... was the battery, even though a snap on tester said it was OK, if there not spot on, the truck doesn't like it.... Pete
7th Jul 2014 9:32pm |
Thanks for the help guys, I would have thought battery myself, but when garage man connected his jump leads on Sat, despite 13.5v available, nothing was happening. 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!) |
7th Jul 2014 10:07pm |
Thats why I would discount the battery unfortunately, I had full power and still nothing, hope its not that |
7th Jul 2014 10:10pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
I would go battery as well. Got to be the cheapest and easiest thing to try. These monsters don't like have a battery which isn't 100%. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
7th Jul 2014 11:52pm |
In addition to the battery I suggest to also look at the alternator. Have it checked by a good auto electrician because it can goose the battery and upset the voltage/current of the system if not working properly, independent of the battery and not always switch the generator fault light on.
8th Jul 2014 12:57am |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3739 |
I had a similar issue several years ago on an 06MY it was the ignition switch - £300 odd at mainagent sorted it 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
8th Jul 2014 6:25am |
I remember another post on ignition switch where the barrel was left in place and only the switch itself was replaced. I thought it cost a lot less, maybe check with Dan of Duckworth what the price of the switch itself is before ordering via main dealer and the likes.
8th Jul 2014 7:03am |
Back home as of yesterday, FF at Davis in Llanybydder this afternoon, they are very busy and have said they may not get to it until next Monday, but will try to fit it in earlier if they have a gap appear.
8th Jul 2014 2:49pm |
