Home > Technical (L322) > quick question
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
quick question
Hi everyone.
as you may well know I am fitting a wheel power chair hoist in my ffrr.
I would like to know about battery disconnect procedure, as I have to fit an inline fuse and seperate live all the way
from front. Read wiki but do you leave a door open to let car shut down or doesn't it matter, as I notice when you open a door I can hear a fan running. Thanks in advance and sorry if it's been covered before.
Greg.
Post #268784 3rd Jul 2014 6:49am
iphs
England 2003 Range Rover Vogue Td6 Buckingham Blue
I'm no expert but for what its worth I do the following.
Turn off the ignition and remover the key. Open the bonnet for so you can get at the battery. Close the doors and walk away, I leave it for about 15-20 minutes then disconnect the earth lead, leave it alone for another 15-20 minutes and then disconnect the Pos lead.
By opening the bonnet early, you don't need to open the door again until well after the battery is disconnected.
Hope that helps.
Post #268788 3rd Jul 2014 7:13am
gregdav
Thanks for the quick reply.
Just a bit unsure as my knowledge of electrics isn't brilliant.
I will do that and thank you Thumbs Up
greg.
Post #268791 3rd Jul 2014 7:21am
iphs
Don't forget when reconnecting, Pos lead first then earth. After starting the car turn the steering hard left then hard right to reset the steering.
Post #268792 3rd Jul 2014 7:26am
I'm not sure if it's of any use to you but there is a permanently live 16mm2 cable fused at 100A at the rear of the car.
Would this be sufficient to feed your chair hoist?
The 100A cable feeds the rear fuseboard in the car and is generally running at nil consumption when the car is stationary which means nearly all of the 100A would be available to supply your hoist.
Using this cable would obviously obviate the need for an additional cable to the front of the car avoiding the cost and hassle involved.
What sort of power supply do you need for the hoist?
Post #268797 3rd Jul 2014 7:43am
gregdav
Thanks for the replys.
I was told by the chap who sold it me, to put a seperate lead in as it will isolate anything other than the
hoist thereby eliminating any possibility of trouble from the cars electrics.
I have fed the wire through and need to solder each joint. The brackets I have fabbed and welded then
bolted in, just need to adjust one.
so nearly there will do my best to take and post some pics. But I'm a bit technophobic where thats concerned.
cheers everyone such a great forum this.
Post #268802 3rd Jul 2014 8:02am
Connecting into the rear cable wouldn't have caused any problems, it's a direct connection to the battery +ve terminal.
In reality it's no different to what you are doing.
Hope you get it all working successfully. Thumbs Up
Post #268803 3rd Jul 2014 8:09am
gregdav
Cheers Thumbs Up
Post #268806 3rd Jul 2014 8:17am
gregdav
Thank you everyone. The hoist is up and running.
I've lifted the power chair off the floor about 6 inches can't go anymore cus I need the correct mushroom head fittings to connect to the lifting bar. All went well with battery disconnect and reconnection afaik everything is okay just need to do a test drive.
What super people you are on this great forum Thumbs Up Thumbs Up
Post #268939 3rd Jul 2014 6:51pm
mjdronfield
Post a few pics up when you have done. Good to see how you have done it.
Just north of Stafford ? I spent 10 years living in Stone and another 10 living in Lightwood, before moving to Chesterfield in 2011.
Nice area to be.....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #268941 3rd Jul 2014 6:57pm
gregdav
When I have a spare hour I'll post some pics.
I'm about midway between stafford and stone theA34 is approx a mile up the lane from me so quite in the sticks, all we have is a post box a public telephone and church, been here nearly 5 years as we needed a bungalow for wifey.
glad to hear you know the area,
oh and we love it out here Cool .
On a note of the equipment I bought if anyone is interested in anything to do with mobility this chap has just started up on his own been doing this and other equipment for at least 16 years and a very nice chap he is. I know were not allowed to advertise so if you would like to pm me I will give you his number. Thanks again greg.
Post #268951 3rd Jul 2014 7:37pm
mjdronfield
I can recommend Ashley 4x4 if you need any work done on the rr. They are local and Land Rover trained.....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #268953 3rd Jul 2014 7:42pm
gregdav
Thanks very much I've been past their place a few times and did wonder, but a lady in our village used them and did mention it. Where I used to live at hednesford I used mercia 4x4 for my disco's but a bit far to go now.
will keep them in mind Thumbs Up
Post #268960 3rd Jul 2014 8:19pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
I've a pal in rugeley who's got a machine shop and is a 4x4 expert just off power station road, they do engines that others are scared to do including for car SOS TV prog Smile _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #269005 3rd Jul 2014 10:51pm
gregdav
Scottyav. Noticed from previous posts your local. Its good to know we have a few good places
we can call on if need be. My son, wife and family live in rugeley I know the area very well.
must get my car booked into neil smith for gearbox service. Topman! Thumbs Up
Post #269018 4th Jul 2014 5:01am
