Home > Maintenance & Mods (L322) > Front air springs replacement. Short cut.
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
I have recently changed both front air springs.
First I did the offside with the help of a friend and following instructions from the online manual. Fortunately the nuts came apart quite easily and the job took about an hour.
Yesterday I decided to tackle the nearside. I was on my own but once again used print-outs from online manual. I couldn't see the reason for disconnecting the ball joint or removing the brake calliper (both mentioned in the manual) so didn't bother. Apart from bottom 2 nuts being very stiff (I needed a breaker bar and 3 foot long extension). The job went well.
In total I only needed to undo 6 nuts/bolts (excluding the wheel obviously). No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #265735 16th Jun 2014 3:43pm
Andy
I did mine last year without a manual. I didn't realise you were supposed to disconnect the ball joints and brake calipers. I didn't. The only hard part was getting the large bolts out.
Post #266133 18th Jun 2014 5:56pm
netsonic Steve
United Kingdom 2002 Range Rover Vogue Td6 Epsom Green
how did you re pressurise the bag before lowering to the ground, ...........is it a simple case of replace fuse and switch ignition on..........
Post #266160 18th Jun 2014 9:50pm
Andy
I just started the car and they inflated.
Post #266164 18th Jun 2014 10:10pm
birchyman71
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
I did mine a few weeks back in exactly the same way but before inflating I lowered it on to low axle stands to take the weight before starting the car up to inflate them , I would advise getting the alignment checked as you can't be 100% sure it's the same and for the sake of £30 it might save wrecking some tyres
Post #266229 19th Jun 2014 12:05pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
great shortcut. I would be tempted to (when the car is back settled and the bags reinflated) loosen and re-tighten the bolts holding the arms to the subframe to ensure the pre-load is not messed up.
Steve
Post #266230 19th Jun 2014 12:10pm
