Home > Technical (L322) > Could this be the cost of something to go |
During the last 2 days i have noticed a (hard to describe ) whistling noise when i slightly rev the accelerator when the car is just sitting ticking over ... kind of sounds like the noise you would get when the wind is blowing through old window frames but not too noisy ...
9th Jun 2014 8:28pm |
mbdj Member Since: 14 Jul 2010 Location: scotland Posts: 98 |
Had the same noise on mine lasted about a week then the alternator failed fully covered under warranty . |
9th Jun 2014 8:41pm |
Never took out the extended warranty on mine ... looks like the wallet will be out if that is whats wrong with it ... ====================================
9th Jun 2014 8:48pm |
Mine had a plastic burning smell under the bonnet for a few days before it failed . |
9th Jun 2014 8:53pm |
Need to keep my nose out for that ...nothing as of yet ... ====================================
9th Jun 2014 8:57pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Smell of burning plastic - was that your credit card? |
9th Jun 2014 8:58pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Mick exact same as mine turned out to be alternator symptoms as you described Present :2008 TDV8 HSE
9th Jun 2014 9:10pm |
So if its the alternator anyone know a rough price for a garage to supply and fit ====================================
9th Jun 2014 9:26pm |
Land rover quote it as a 3.5 hour job I think alternator itself is about 350 pounds. Hope that helps Present :2008 TDV8 HSE
9th Jun 2014 9:49pm |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 |
TDV8 alternator issues, seems they all fail at some point. I guess my time will come |
9th Jun 2014 10:44pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8513 |
I got my oem denso alternator from carparts4less (basically ecp) and got a decent general mechanic to fit it,
10th Jun 2014 6:48am |
as has been said, refurb all the way they do the work and you just hand over the cash. Done it on our past car starter and alternators before when we've had an issue and they've usually lasted longer than the original part FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
10th Jun 2014 8:27am |
