Home > In Car Electronics (L322) > Fitting hybrid tv tuner HELP!
Dr Meat
United Kingdom 2006 Range Rover Vogue Td6 Java Black
Hi all, I brought a hybrid box for my 06 l322 the part No. is AH42-19C063-AE
I've pluged it in but cannot get it to work. What pal setting do I need to select? Also there is an extra green plug socket in the hybrid box that the old analog box doesn't have. any advice would be great thankyou.
Post #258215 8th May 2014 11:24am
that part number should be ok, try pressing auto to store some channels..
..also try a forum search, theres loads re this.. ... - .- -.
Post #258218 8th May 2014 11:42am
Dr Meat
Does it matter that it has an extra green plug thats not being used?
Post #258223 8th May 2014 12:04pm
dunno, i've never fitted one but do a search and you'll probably find an answer .. ... - .- -.
Post #258228 8th May 2014 12:19pm
Dr Meat
Post #258229 8th May 2014 12:20pm
Discotigger
Don't worry about the extra green plug, it's not needed for the TV Tuner to work. Make sure that your location is set to United Kingdom on the settings menu and set to PAL not NTSC. Also, you may find that your in a location where the FF antennae can't pick up a decent signal, so you may need to have a drive around to get a picture.
Where did you get the TV tuner from? If it's a second hand unit, there's always the possibility that it's a duff unit, so might be worthwhile getting it checked out in someone else's FFRR.
Post #258257 8th May 2014 1:59pm
Dr Meat
Thanks for all the responses
I Pulled the whole lot out to see in there was a missing connector behind the units Big Cry
finally got it back together and did a battery reset, Only F'king working Mr. Green
But doesent work even with a key in the ignition & in park. is there a way to get this changed?
Post #258264 8th May 2014 2:19pm
so it works when the engine is running and in park?
as for having it work when in motion , we tend to scorn on that because of the dangers of being distracted whilst driving. ... - .- -.
Post #258265 8th May 2014 2:23pm
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
Just checking that you have the parking brake on as well as mine only works when in Park and with the parking brake applied unless I put in to test mode. It is designed only to work when parked as a safety feature although there are ways to bypass this apparently. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #258270 8th May 2014 2:41pm
Dr Meat
No it is only working without the key in the ignition, as soon as in put the key in the screen cuts out with "for your safety blah blah" the hand break is on
Post #258276 8th May 2014 3:21pm
Dr Meat
Im not trying to get it working whilst in gear, just as it should thanks.
Post #258277 8th May 2014 3:23pm
Dr Meat
Ebay
Post #258278 8th May 2014 3:37pm
rej
Do you get the red light on the dash when the handbrake is on? My TV would not work for a while as the contact was not sensing the handbrake being on.
Do you get the sound from the channels you pick-up when you run the engine and the picture goes?
I'll try to remember to see if mine works without the key turned on when I get home (I know I don't get any channels at work) There is a difference between knowing your sh!t and knowing you're sh!t
Post #258279 8th May 2014 3:45pm
Dr Meat
Ive just had a look and there is no red light on the dash when the handbrake is on! I have never noticed this before. Is this an easy fix? sound works and just pulled it outside my unit and got a load more channels.
Post #258282 8th May 2014 3:56pm
rej
The sensor on mine that was not registering was at the base of the parking brake (I was able to see by removing the cupholder/ashtray from the centre unit) From memory it is a white plastic block that moves with the handbrake, mine was being block by a misplaced wire stopping it moving freely.
I have the actual mechanical handbrake so not relevant if you have the electronic one without a proper mechanical handle. There is a difference between knowing your sh!t and knowing you're sh!t
Post #258284 8th May 2014 4:02pm
