Home > Maintenance & Mods (L322) > Inner track rods
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Inner track rods
I changed inner track rods and track rod ends last week, together with new boots and clips. Very straightforward. After fitting, I started getting what I thought was worn suspension rattles which got worse by the day.
Got underneath it today, removed the boots to check the spindles. One had come loose by 2 or 3 turns. I must not have tightened it sufficiently and when it susbsequently when for alignment, they must have loosed it during adjustment.
The moral is make sure you tighten them up properly. A few swings on my big 18th adjustable today has them fully tight and I will monitor. Another costly wheel alignment also required.
Sloppy work by yours truly. Anyone attempting this job, please make sure properly tightened. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #257506 3rd May 2014 7:52pm
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
Thanks for warning Thumbs Up 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #257527 3rd May 2014 11:07pm
Good advice!
Try F1 autocentres for alignment, did my toe on the hawkeye for £30 and checked the rest. Some kwikfits also have a hawkeye and our local one has checked mine for free before now...... There is nothing that can't be fixed with a hammer😜😜
Post #257562 4th May 2014 9:12am
RRBlue
Funny you should suggest that, I have just changed to an F1 Autocentre after problems with a long standing tyre shop that I have always used, but who recently lost my trust. F1 were fast, clean, pleasant, good value and have all the gear. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
1992 Mercedes 300D
Post #257572 4th May 2014 9:47am
Thumbs Up Good advice sir Thumbs Up
Post #257577 4th May 2014 9:58am
