Home > Technical (L322) > HELP In tank fuel pump(pic added)
trainmanone
England 2002 Range Rover HSE Td6 Oslo Blue
Hi gang got a replacement sender unit for passenger side but don't know how to attach the spring loaded part to the left hand side of the tank
ive got rather fat arms so don't want to get stuck feeling my way round
best regards pete have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #254879 17th Apr 2014 4:27pm
It's a horrible job!
Run the tank as low as you dare really, the easiest way to do it is to pop up the drivers side unit and pass the pipes and connector thru from the pass side and try and hook them on with the main unit partially out of the tank.
Long arms and nimble fingers help a lot.
I'm just round the corner if you want a hand drop me a pm:) FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #254915 17th Apr 2014 11:25pm
trainmanone
well battery fully charged and both pumps running, pump removed from tank and only about a centimetre of fuel in bottom of driver side tank, pass side about four to five cm of fuel.
how thinking low fuel but shows quarter of a tank on gauge. have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #255258 20th Apr 2014 10:35am
trainmanone
UPDATE
Hi all just to update you all car now fixed. put more fuel in after replacing pump in tank and under pass side.
thanks to kingpleb for calling and offering his assistance
Post #255426 21st Apr 2014 3:13pm
Congrats sir... Will was right, a pig of a job it is... Rolling Eyes
Post #255448 21st Apr 2014 5:29pm
Worst bit is the slime and then getting your arms clean and smell free afterwards Sad gets right into your skin FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #255455 21st Apr 2014 6:20pm
