Home > Technical (L322) > rear brake disk red hot
Wookie
United Kingdom 2006 Range Rover SE TDV8 Giverny Green
Rear offside brake disk is red hot. Is this another common fault? I don't know how the electronic handbrake works could it be related?
Post #253082 6th Apr 2014 2:56pm
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Rear calipers binding is a very common fault - most likely this, just do a search and you should find lots of threads Thumbs Up 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #253083 6th Apr 2014 2:58pm
Also update your car details in your profile area please Smile
And for you issue you are probably best getting a new set of rear discs and pads and a new caliper for that side. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #253086 6th Apr 2014 3:32pm
Wookie
Once again thanks for the advice
Post #253098 6th Apr 2014 6:09pm
this might help Jonathan,
http://www.fullfatrr.com/forum/topic19932.html ... - .- -.
Post #253099 6th Apr 2014 6:19pm
billcyn
United Kingdom 2008 Range Rover Vogue TDV8 Epsom Green
Rear offside disc overheating
Had mine done a couple of months ago. New caliper from Britparts at £86.22 incl postage and fitting £25 by
local garage. No need to return old caliper on this occasion.
Post #253100 6th Apr 2014 6:30pm
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
Have just done mine (nearside overheating). Big Cry
Was caused by the Calliper Piston being seized. Sad
Re-manufactured Callipers and pads from Dan at Duckworths (Genuine Land Rover rather than Censored part!!), fairly easy job to do, and bleeding the brakes with a Gunson's Easybleed kit was the easiest brake bleed I have ever done Very Happy
I would always change both sides, from experience on previous cars (although not FF admittedly) if you are having problems with 1 side the other is not usually far behind it so you may as well do both sides together rather than having to do the other side in a couple of months (and probably trashing another set of pads in to the bargain!)
Best of luck! Thumbs Up 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #253125 6th Apr 2014 8:54pm
ebajema
As soon as the one went on the 06 SC, I replaced both. Haven't had an issue since. MY 2010 5.0 SC Galway green and sand interior!!
Post #253134 6th Apr 2014 10:43pm
