![]() | Home > In Car Electronics (L322) > Really sorry...iPod again |
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 ![]() ![]() ![]() |
It will work as the infotainment kit is identical. The only difference is the location of the module you need to connect to and you need to fabricate a method of installing the connection point. I recommend putting it vertically on the RH side of e glovebox fuse box and trimming the fuse box door to fit.
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2588 ![]() ![]() ![]() |
nwmpg, have you got an aux |
nwmpc, bloody eyes |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35515 ![]() ![]() |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 ![]() ![]() |
. . . As my dad used to say -
nwmgc Member Since: 27 Jan 2014 Location: London Posts: 159 ![]() ![]() ![]() |
Rosco and TugRR: Muddled indeed is what I am! No aux so, of course, the downward spiral to madness that occurs when getting into this subject.
^ . . . If you look at my car profile above, you'll see I'm in the same boat as you |
You may be right. Tricky even with man-maths |
The land rover kit is made by Dension and is a modified gateway that can be purchased for other vehicles. That said on the LR one will work...
Does the Denison Gateway work ? after all these years I have never heard of any one doing so .
Brilliant - thank you very much! |
Just found this whilst reading the papers: http://www.justconnectme.co.uk/justdrive-d...r-adaptor/ Looks neater than Parrot or ezi-DAB... |
