Home > Maintenance & Mods (L322) > Changing rear pads and discs on a S/C
Chauch
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Hi guys I have read a few threads about rear pads and discs being more complicated than the fronts with Brembos. Is this only true for those equipped with Electronic Parking Brake?
As a 2006, mine has a standard hand brake, does this mean the rears are a straight forward job to change?
Many thanks in advance.... 4.2 Supercharged Vogue SE
Post #246561 5th Mar 2014 9:52pm
DO NOT PULL THE DISC OFF UNTIL YOU DE ADJUST THE HAND BRAKE...... Very very very important (you'll pull the pins through the backplate and thats a very expensive mistake) Thumbs Up
Removal assistance should be in the wiki sir Thumbs Up
Post #246585 6th Mar 2014 12:02am
Chauch
Many thanks - this was the bit that made me nervous Thumbs Up
I have looked through the wiki and can find handbrake adjustment, but the only reference to rear brakes that I could see was the TDV8 rear calliper, and there was no mention of the de adjustment of the handbrake….
Any idiots guides anywhere?? 4.2 Supercharged Vogue SE
Post #246589 6th Mar 2014 6:50am
this should help,
http://www.fullfatrr.com/forum/topic23121....rear+discs ... - .- -.
Post #246591 6th Mar 2014 7:11am
Chauch
Thanks Stan Thumbs Up
So I can see about lining up the inspection hole and bung at 6 o clock. To actually release the shoes is then obvious?
I just do not want to get half way through and stuck on the drive! 4.2 Supercharged Vogue SE
Post #246593 6th Mar 2014 7:43am
Try this my friend... Thumbs Up
http://www.landyzone.co.uk/lz/f10/l322-ran...13339.html
Post #246596 6th Mar 2014 8:17am
Chauch
You are a gent - all sorted without drama Thumbs Up 4.2 Supercharged Vogue SE
Post #246723 6th Mar 2014 6:28pm
Googsy
I'm still fearful of doing mine was it simple? Like you I'm nervous as I don't have a Craig on the Island to run to .Fronts were very easy Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #246730 6th Mar 2014 6:47pm
Chauch
I was able to cheat and used a friends workshop - I relayed the information and by the time I came back with a cup of tea, it was done... 4.2 Supercharged Vogue SE
Post #246731 6th Mar 2014 6:49pm
