Home > Technical (L322) > Zf Gearbox
mike & the mechanics
United Kingdom 2007 Range Rover Vogue SE TDV8 Galway Green
Zf Gearbox
My gearbox has always done this & is smooth with no probs but when started from cold I have noticed since owning that for the first mile when I let my foot of the throttle (its downhill out of my village) the revs drop to tickover with no gearbox braking. Its not dropping out of gear as when you apply the throttle it smoothly picks back up. So to me it has to be torque converter slip. Recently changed the oil & filter with no horrible surprises so wonder if its a design feature until warm? Any ideas guys. Mike Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #237366 26th Jan 2014 9:50pm
stu
no expert on these matters, but it takes a minute or two, to get things up to temperature before the torque converter locks up. I have an automatic citroen and it behaves exactly the same on a morning, revs very high for first mile or so and when things have heated up drops about 5/600 revs without moving my throttle position as the convertor locks up.
I don't think you have anything to worry about.
obviously someone will correct me if I am talking out my backside!!! Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #237510 27th Jan 2014 6:07pm
T24RES
Mine does the same as you describe Mike when its cold.
Post #237512 27th Jan 2014 6:32pm
Thanks guys,I could not find anything written anywhere & decided the best way to find out was ask Thumbs Up Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #237583 28th Jan 2014 8:12am
E4 GUY
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I have got into a habit of driving first 100 yards to the end of my road in Manual (1st gear) when cold.
Just to get the juices flowing.
If I leave in auto, the first change (to 2nd ?)was a slight thump. Alcohol and eBay is never a good mix
2006 4.2 Supercharged, Java Black
Post #237655 28th Jan 2014 11:54am
That's a good idea guy as my drive down to the road is very steep & I have to brake all the way down Thumbs Up Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #237661 28th Jan 2014 12:11pm
E4 GUY
...goes without saying that Mrs E4 starts car, doesn't wait for any warming up etc and blasts off up the road in auto like she's at Santa Pod ! Big Cry Rolling with laughter Alcohol and eBay is never a good mix
Post #237672 28th Jan 2014 1:06pm
mzplcg
I believe (as it was explained to my) that this is because the torque converter doesn't lock up until the ATF is up to temperature. By allowing it to slip it creates more heat and warms the 'box up more quickly.
Post #237674 28th Jan 2014 1:21pm
