Home > Technical (L322) > FBH Remote/ Receiver problem?
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Hi All
my FBH remote or receiver seems to have developed the fault of not working remotely. The system will turn on and off with the remote as long as the remote is within about 6 inches of the receiver.
If the remote is more than 6 inches from the receiver the green or red lights just flash when I press the on or off buttons. If the remote is within 6 inches of the receiver the FBH fires up or shuts down and I get a constant green or red light when I press the buttons for on and off
I have tried new batteries in the remote and that has not fixed the problem.
It works with the car locked or unlocked as long as I am standing at the back just by the receiver.
The remote worked last year from inside my house (25meters or so).
I have the T89/90 remote
Any ideas? is there a way I can test to see if it is a remote or receiver problem? I have checked in at the back and all the cables look and feel like they are attached
Thanks
Andy 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #234285 12th Jan 2014 12:45pm
redshovel
United Kingdom 2010 Range Rover Autobiography Black TDV8 Barolo Black
I had a similar problem with my remote after 4-5 years of use. I indeed changed the battery too - but it was one from a "value pack" purchased in a Pound shop Embarassed and made no difference.
After changing it for a branded battery it went back back to normal Thumbs Up
Worth trying a different battery if u haven't already.
Post #234295 12th Jan 2014 2:50pm
Andy_J
Thanks, I will try new batteries, but it is Duracell that I put in it 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #234313 12th Jan 2014 4:09pm
jak480
Norway 2003 Range Rover Vogue Td6 Zambezi Silver
Control the contacts befor you put the battery's in maybe slightly oxidated.
Post #234330 12th Jan 2014 5:31pm
Andy_J
I have tried new batteries and given the contacts a clean and this has not improved the range.
Anyone got any other suggestions? before I try a new transmitter.
is there anything I can check on the receiver side with my IID tool? 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #236033 20th Jan 2014 12:58pm
Have you checked the arial connection ? 2008 MY Supercharged
Post #236193 21st Jan 2014 1:11am
taskam
Probably daft question, but have you put the correct voltage battery in? Some RF fobs use 12v batteries that are physically the same size as 1.5v ones....I'm not familiar with the T89/90 one. 2007 TDV8 Vogue SE Java Black
Post #236258 21st Jan 2014 12:33pm
Andy_J
Axle, I have had a look in the rear compartment by the fuse box and the aerial connection looks and feels secure.
taskam, I took the old batteries with me when I bought the new ones, double checked them and they are both 12v. I did notice the Duracell batteries seemed to have a small lip on them, but the energiser ones don't and are tight in the holder 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #236365 21st Jan 2014 9:21pm
Googsy
Is aerial on top or rear of fuse box ? I'm not sure if I have receiver as yet thanks. Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #236366 21st Jan 2014 9:30pm
The receiver uses the TV arial via the signal booster if memory serves me. 2008 MY Supercharged
Post #236406 22nd Jan 2014 1:03am
Andy_J
Still can't get my FBH remote to work, so far I have tried the following
1. new batteries in Remote
2. Paring procedure a few times, been disconnecting the 3 pin plug from Webasto receiver in rear fuse box
3. Made sure main battery is fully charged (new Bosch one in March following alternator problem)
4. Checked for 12v supply to receiver unit
5. checked the aerial connections
Anyone got any suggestions before I go on e-bay and buy a new remote? 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #284121 2nd Oct 2014 6:38pm
Steverr
United Kingdom 2003 Range Rover Vogue Td6 Zermatt Silver
Is it cold enough for the fbh to fire up ?
May be worth a email to webasto to see if it's just telling you what it's doing ???
Do the lights flash on the remote ?
Also drop French Mike a email... He's the kiddy on these bad boys tignous84@free.fr
Steve
Post #284327 4th Oct 2014 8:42am
taskam
My guess is that it's the antenna connection in the remote fob that's bad. I think getting a new one from ebay would eliminate another variable, can always sell it on. 2007 TDV8 Vogue SE Java Black
Post #284342 4th Oct 2014 10:14am
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Can you not try someone else's fob on yours (if you have someone close by that doesn't mind you re synching thiers to yours for testing purposes) that would eliminate/prove the remote at least ?
Post #284382 4th Oct 2014 3:02pm
Andy_J
Not aware of anyone local to me with FFRR and an FBH remote.
Ordered a new transmitter off E-bay and will try that
- Steve, lights on the transmitter work, press either button and I think I get 6 flashes red-off, green-on
- taskam you could be right about an antenna problem as the range dropped to about 12" before it stopped working (not worked since even with new batteries and following all the programming) 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #284406 4th Oct 2014 5:23pm
