![]() | Home > Maintenance & Mods (L322) > parking sensor and rear bumper trim.. |
BILLTU Member Since: 23 Jan 2013 Location: Glos Posts: 73 ![]() ![]() ![]() |
Are sure the front sensors aren't working? Thought mine weren't working when I parked bonnet first in my space, then remembered the sensor system is only automatically activated when you select reverse. You have to manually select it if you want them to work and you haven't selected reverse. Just a thought. 2016 3.0 Vogue
@gm1 -
greasemonkey1 Member Since: 22 Sep 2013 Location: london Posts: 157 ![]() ![]() ![]() |
thats a very good point that and it makes perfect sense,i will have a look @that tomorrow morning and get back to you...i feel like such a numpty... ![]() ![]() ![]() ![]() |
thank you for your helpful advise pld118,i will give that a go...much appreciated.. ![]() |
Welcome... GTechniq C4 is supposedly the best thing you can get for restoring int and exterior plastics/trim but is about £30 plus for a small amount of liquid and tbh, I've got some but could not believe how good, easy and pleasant to use the trim/tyre gel on the link is on the RR.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8689 ![]() ![]() ![]() |
If all else fails the top trim can be easily removed and replaced. There is nothing that can't be fixed with a hammer😜😜
for a while the above method gave me hope that maybe it was me not manual selecting parking sensor button thus why they wont working but unfortunately i tried yesterday and nope not a beep,left the key in the ignition pressed the parking sensor button and went round the front and listened for that clicking ticking from the sensors,looks like the front parking sensor are messed up..i will wait till summer time and take the front bumper off and take the front sensors off and replace them.. |
jak480 Member Since: 06 Dec 2013 Location: Degernes Posts: 44 ![]() ![]() ![]() |
If You can't hear any of the front sensors they might be deactivated.
cheers jak480.. |
