Home > Maintenance & Mods (L322) > Looking for someone to stop the water ingress
woodchopper23
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
Jo 90,
I have the same rust as your photo......
I have had it re sprayed twice and thought it was mud and moisture getting behind the arch liner and causing it. seems you guys are saying its cused by the water that gets in the spare wheel well occasionally. i;ve tried removing my boot door seal, siliconed all of the seams and replaced... no effect. i think i might have to take the rear bumper off to try sealing around there. I cannot seem to get at the sunroof drains? They also seem quite far removed from the rear quater pannel / boot? MY2010 TDV8 Vogue Ipanema Sand
2002 V8 Vogue Oslo Blue - Gone.
Post #153115 24th Nov 2012 12:36pm
mrd1990
United Kingdom 2002 Range Rover HSE Td6 Oslo Blue
@Joe90
rusty bolt - off side:
Inside rust:
Hope the rust spot doesn't get worse, are you 100% sure you don't have water perhaps under the tyre?
I had a quick look this morning before the rain to see what's going on. The fabric on the left side was bone dry, under the tyre it was like sea world aquarium.
I have noticed the fabric on the left is only wet when it rains for more than ~30min and when the hatch is lifted up I get a small river coming down. My guess is water builds up at the top then seeps in through the rubber seal, slowly finds it's way down the fabric on the left past the amp and into the spare wheel compartment.
For now I have cleaned all the water out, cleaned up and laid some newspaper to see if that gets damp, I guess the water under the wheel built up over time. New rubber seal me thinks!
Post #153123 24th Nov 2012 1:13pm
woodchopper23
Nicedayforit,
I live near you! just outside of Workington to be precise
I might come and see where you done all of you investigating to solve your leaky land rover, so i can sort mine! Very Happy MY2010 TDV8 Vogue Ipanema Sand
Post #153180 24th Nov 2012 6:48pm
So you do. Smile
Let me know when you are up this way and I'll try and give you some pointers. Thumbs Up
Post #153204 24th Nov 2012 7:35pm
woodchopper23
maybe ill have a look up the market on a sunday next year when the weathers better. MY2010 TDV8 Vogue Ipanema Sand
Post #153219 24th Nov 2012 8:00pm
Post #153223 24th Nov 2012 8:08pm
321lew
United Kingdom 2003 Range Rover Vogue SE Td6 Adriatic Blue
under rear tailgate hinge is a hole!!!!
No gasket!!
clean with toothpaste and cover with silicon sealant.
no more water in my sat nav or amplifier
replaced sat nav and repaired the amp before ripping out headliner to find actual leak.
Post #233128 5th Jan 2014 10:18pm
Mustard
Im in your neck of the woods mate and had this problem bad, got it all sorted out in the end, PM me if you want me to meet up with you to show you all the bits we focused on to make sure its gone for good.
Post #233140 6th Jan 2014 12:56am
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
With all that rain we had last night and reading this I thought better have a look at the rear of the FF, bound to have some in there..... Very Happy NOT a drop of water in the usual places FF's leak, nothing in the spare wheel well either, oh and I don't have one of those plastic bags over the electric's on the left side rear either Mr. Green .....no I'm not smug, its goina happen some day then I'll Big Cry If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #233159 6th Jan 2014 8:39am
321lew
Real pig the hinge leak. I recommend to clean and smother the hinge with silicon.
You can not see hole from above but it must be there as since I covered with silicon no water ingress.
what were LR thinking off not putting a gasket there.
Post #233482 7th Jan 2014 8:04pm
