Home > In Car Electronics (L322) > Where to get sat nav and tv modules?
rich89
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
I need a sat nav and tv module for my 2002 vogue as they weren't in there when I bought it.
At the moment the stereo screen is blank but it does work, I can listen to the radio/tape player but it will turn off after a couple of minutes and I just have to turn it off and on again (as you can imagine, this is very annoying)
What are the part numbers that I need as I need this working.
If I'm not going to watch tv, would you recommend just bypassing the tv module?
Thanks.
Post #232951 5th Jan 2014 11:32am
Do a search on here for MK4 BMW DVD nav units... Well worth the upgrade imho Thumbs Up
And yes, bypass the TV Tuner as it will be analogue anyway!
Post #232953 5th Jan 2014 11:41am
rich89
So I just need this?
What is better about it? Better map?
http://www.ebay.co.uk/itm/MK4-DVD-RANGE-LA...19e616cab5
Post #232959 5th Jan 2014 11:52am
Do a search in the wiki my friend, been covered on here loads of times...
But to be blunt, the LR nav is like a sundial compared to the BMW being a digital watch Thumbs Up
Chalk & Cheese in comparison...
Post #232962 5th Jan 2014 12:00pm
I would be inclined to contact Baris on the Forum...email...xkalibar@gmail.com who I have no doubt will be able to supply you with a Mark4 Satnav unit and up to date disc.
If you don't reinstall a tv unit you will either have to reposition the satnav unit slightly or lengthen a set of cables from the satnav to be able to byepass the tv unit.
Alternatively you can just install a redundant analogue tv unit as a means of installing the standard cables.
To be honest you might be better using a stand alone TomTom unit
Post #232971 5th Jan 2014 12:30pm
But then the Tom Tom wont get the radio working correctly... Embarassed Thumbs Up
Post #232979 5th Jan 2014 12:47pm
hammiegt
Must admit, although my sat nav works, [2003], its the first car ive had with sat nav fitted, and after years of using tom tom, I cant get on with the lr system, so when I got my ff, rather than spent £££ on updating the existing kit to the newer bmw stuff, I bought a new tomtom xl via 135 with lifetime maps and Bluetooth for around £109 on offer at currys, and just got a brodit clip to mount it.
cheers hammie 2003 ffrr v8 vogue
Post #232980 5th Jan 2014 12:48pm
rich89
As Craig has said, it's the stereo not working which is the issue. I would never use the sat nav in the RR.
Post #232991 5th Jan 2014 1:33pm
Ahhh...
The radio going off and then coming back on when you turn it off/on sounds like a fault in the DSP module.
Before spending money I'd be inclined to get your car connected to a diagnostic system and check for logged faults in the sound system. If you are really lucky it may just be a case of clearing a logged fault.
Post #232995 5th Jan 2014 1:52pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
I like this one I brought 14 months ago great sound and very good sat nav mp3 dvd etc Thumbs Up
 _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #233006 5th Jan 2014 2:27pm
if we could only get igo sat nav software onto our FF screens, be it non and touch screen , that would be a major improvement.....
Post #233008 5th Jan 2014 2:30pm
igo Stan? Whats that?
Post #233015 5th Jan 2014 2:39pm
its sat nav software which can be obtained for free of the web and is mostly supplied with chinese after market nav units..its very customisable which different coloured maps and spoken street names etc..
Post #233018 5th Jan 2014 2:43pm
Ahh, i see... Thumbs Up Bow down
Post #233020 5th Jan 2014 2:45pm
rich89
How much was that? I'm fine with an aftermarket as IMO apart from the look. It is much much better.
Post #233023 5th Jan 2014 3:23pm
