Home > Technical (L322) > Amplifier
jowett110
Amplifier
Not being a RR owner (I am from Disco3) I have been asked to find an amplifier for an 02 RR. it has had water damage in it and is now faulty, so a replacement is needed.
Cheers
Paul
Post #632 23rd Jun 2008 5:24pm
Right...I'm not sure if this is a question or not?
Are you looking for a make and model number?
Best way to find that out is to ring a LR Dealer and speak to their Parts Dept to get a parts number, get a price while you're at it for comparison.
Then get on eBay, best place to find parts really, although parts for the L322 are a bit thin on the ground. You could also try picking up a Land Rover magazine and looking up some of the breakers and customisers, they are likely to have a spare one.
Good luck, please let us knwo what you find out. Discovery 4 HSE
Post #633 24th Jun 2008 6:49am
jowett110
LR Part number is XQK 000030, but Googling it just comes up with a site in America. Been on Ebay and they are very thin on the ground to say the least.
Paul
Unnecessary quote removed
Post #634 24th Jun 2008 5:13pm
87RJD
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Hi, I had the same issue with my 2002 TD6, I bought a new one off e bay for £156, it wasn't the same number, a few digits different, and looked slightly different, the plugs were the same and it worked 100%. Just looked back through my pay pal, it came from Britcar (UK) Ltd, see below, as I said this worked trouble free until I sold the car 2 years later.
Land Rover Disco 11 Harmon Kardon Amplifier XQK000050
Item Number eBay Item No. 300674041917
Post #232877 4th Jan 2014 7:05pm
You could possibly have the damaged XQK000030 amp refurbished here
http://www.bba-reman.com/catalogue/Detaile...oduct=2471
Post #232901 4th Jan 2014 9:29pm
mjdronfield
If it's a vogue, it's the bm54 unit you need, but check whether the pins are round or flat on the connectors on the car and make sure the bm54 you are looking at matches. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #232907 4th Jan 2014 10:09pm
mjdronfield
Just had a thought - the bm54 is the radio unit that also houses the main power amps.
If you need the dsp amp, that is different, and my posts are of no use to you........
They are all BMW units, so one from a similar age x5 or 5 series is the same. Have a look under those as well, but double check connectors etc before you purchase......
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #232908 4th Jan 2014 10:14pm
