Home > Technical (L322) > Front driveshafts |
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 |
Hi All, I have an annoying vibration at around 30-33 mile an hour, think it's a front driveshaft on the offside, out of balance or CV worn, on my 2007 S/C. Can any body confirm if the driveshafts are all the same throughout the model years? There are a few on the bay at the moment off TDV8's, I would hazard a guess that they are the same up to 2010???
8th Dec 2013 11:00pm |
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 |
never changed a half shaft due to vibration
8th Dec 2013 11:05pm |
Not triple positive Adam, thought it was the box, but it does it in or out of gear at different rpm, the only constant being the speed, had the wheels balanced, changed a rumbly bearing, checked the diffs seem fine.
8th Dec 2013 11:36pm |
No pulling side to side, stops dead straight, no overheating on the calipers, no drag and no tight spots when spinning the wheels by hand with the car jacked up, had the 4 wheel alignment done |
8th Dec 2013 11:51pm |
if its half shafts
8th Dec 2013 11:59pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16286 |
Warning!!! There is a special tool for pushing/pulling the driveshafts through the hubs... 8 out of 10 times a DIY mechanic wont remove tem
9th Dec 2013 7:38am |
Back to my first point - are all the shafts the same? |
9th Dec 2013 10:37pm |
No... |
9th Dec 2013 11:00pm |
a016738 Member Since: 10 Jul 2013 Location: Massachusetts Posts: 8 |
Would love to know what this actually is...I have the very same on my '07 SC but at near exactly 20 mph...from about 19/20 to about 23 mph...more pronounced after it's sat for 30 mins or more...but it's a very light "whomp whomp whomp whomp" type of sound/vibration. Almost sounds/feels like a tire with a broken belt does but again only at this speed. Tire rotation does nothing to change the problem.
11th Dec 2013 5:55pm |
Craig... I assume the shafts are the same after 2006? No different between the TDV8, 4.2, 4.4 ? It's just I can get my hands on a cheap low miles o/s shaft off a TDV8....hoping it fits the 4.2 S/C |
12th Dec 2013 11:47pm |
Certainly the same as a 4.4V8 sir |
13th Dec 2013 12:03am |
