Home > Technical (L322) > Knock Knock |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8517 |
Sounds like the arb drop link is worn out can get overlooked by some garages easy way to tell is to go out to the car and give it a shake and see if you can feel excessive movement....
25th Nov 2013 8:18pm |
b20wht Member Since: 08 Apr 2013 Location: lincs Posts: 45 |
I also have a similar noise. Its been there since I got the rr and not got any worse. If I had to put money on it I would also say arb link but I have pulled and pushed on mine a few times and cant get any noise or play from it! It had a new strut fitted the day before I picked it up so don't think its that either, its so bloody annoying that I cant find it
25th Nov 2013 9:46pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16286 |
Have the so called "experienced tech's" jacked the car up under the bottom wishbone (to raise the wheel off the ground in its ride position not extended) and tried the bushes, ball joints and ARB links then?
25th Nov 2013 9:53pm |
Need to be on dead flat ground or there will be a torsional force on the arb, and the drop links will be in either compression or tension... There is nothing that can't be fixed with a hammer😜😜
25th Nov 2013 9:54pm |
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 |
Try tightening the pinch bolt on the inboard end of the bottom track control arm, I think it can make this noise, it's difficult to find by just prying the bush/ arm, it will only move a fraction under the full weight of the corner when a direction change is made, the tiny bit of movement is amplified through the subframe |
25th Nov 2013 10:00pm |
ksmith100 Member Since: 20 Apr 2012 Location: Stirling(ish) Posts: 77 |
Thanks for the replies.
26th Nov 2013 9:40am |
L322RR Member Since: 06 Oct 2011 Location: Düsseldorf Posts: 51 |
Had exactly the same stuff, came from the steering ball joint. Was making me crazy. Excessive play, and after a year, brake disc warped. Changed (+ both discs), noise gone. |
26th Nov 2013 2:49pm |
That's interesting, would you have a part number of diagram of that part to confirm? I havent had any issues with brake discs or brakes in general. TIA You are either at Le Mans or waiting for Le Mans RSW MKIII V2 All Comms in Central Scotland |
26th Nov 2013 2:54pm |
No I don’t, had it done by a forum member. But what he did is he jacked up the car, and pivoted the wheels, klonk was then very noticeable, and you could see the play. Discs problems happened much latter. |
26th Nov 2013 3:04pm |
Unnecessary quote removed
26th Nov 2013 3:10pm |
steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356 |
With the car on the ground loosen the inner bolt on the lower arm and then re tighten it. If it was tightened on the jack the bush will we under the wrong load it gives a small knock I found that out when I did mine |
26th Nov 2013 3:28pm |
26th Nov 2013 3:31pm |
Monty1 Member Since: 07 Oct 2012 Location: Middlesbrough Posts: 181 |
i had the same problem it was the track rod end |
27th Nov 2013 8:25am |
No play or movement in the track rod ends You are either at Le Mans or waiting for Le Mans
27th Nov 2013 8:37am |
